20 Most Recent
Lexmark Z617 InkJet Photo Printer Questions & Answers
NO TENGO EL DISCO SE
Por favor, visite el sitio web de Lexmark para descargar e instalar la impresora Lexmark Z617controlador de la impresora en su ordenador. Seleccione el sistema operativo>> descargaejecutar el archivo. Sólo tienes que seguir las instrucciones en la pantalla del ordenador.
Nota: Esto se traduce utilizando translate.google.com.
My printer doesn't work as
Hi Bianca!
What you should do is to clear the print spooler - the printer queue.
If you're using windows, right click on my computer and then press in
"Manage", in the opened window go to "Services and Applications" and
then "Services". go down the alphabetical list in the right window pane
until you come to the service with the name "Print Spooler". Right-click
this entry, then select "stop". This will stop the service that holds
your print queues. Leave this window open, press on start and then type
"spool" in the search bar (or in the "Run" command line if it's windows
xp) and press enter. In the opened window, go to a folder named
"PRINTERS", and Delete every file within this folder to empty the jammed
print queue (pressing the "ctrl" and "a" keys will select all files and
then you can just
hit "delete"). Close the explorer window now that we have emptied the cleared spool files, and return to your Services window. we must re-start the Print spool service, and do so by right-clicking the Print Spool entry and selecting "Start" from the list. Close the services window and try printing again. It should work now. Good luck!
Hi.. i have a lexmark z617 printer and everytime i
When did this start happening?
After a long time not being used, the ink dryes and clogs the heads. Try cleaning the heads and install a new ink cartridge. Run any fresh install that is issued with the printer.
Lexmark z617 printer not working, printer
When you say "printer cartridges shooting from side to side when poweed on or lid opened & closed", do you mean that it's banging from side to side? Turn off the printer. Remove the cartridges from the printer. While the cover of the printer is open, check inside for anything out of the ordinary like any tapes or strips that are loose. If none, turn off/on printer and reload the cartridges. If the banging noise is still present, I suggest you contact Lexmark Technical Support to further investigate the problem. It might be a mechanical problem in the printer.
Lexmark z617 printer - the paper will not feed
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Lexmark printer
Yes, there is a driver on the Lexmark web site.
www.lexmark.com/ Technical Support>> Drivers and Downloads >> OS Compatibility Select Ink Jet and then look for the Z617 driver.
Don
