20 Most Recent Brother MFC-210C All-In-One Printer Questions & Answers
Mfc-j5910DW can I change the language to english.? How do I do it?
there does not seem to be anything about language in the settings what words might be useful ..in german ?
8/1/2021 7:21:20 AM • Brother MFC-210C... • Answered on Aug 01, 2021
Mfc machine error AF
You have to fix the scanner flatcable on the pcb. Its disconnected :-)
3/16/2020 2:07:14 AM • Brother MFC-210C... • Answered on Mar 16, 2020
I have got the error message " unable to clean , see troubleshooting and routine maintainance in user's guide" . I have tried all ways in the user's guide and also other suggestions. Please gi
If your your printer cannot clean automatically, your printer head is probably clogged so badly that you will have to do it manually.... your manual should tell you how to remove it...
1/12/2013 4:23:02 PM • Brother MFC-210C... • Answered on Jan 12, 2013
Need to hook up a brother MFC-210c so it can fax
Install the software (Brother MFLPro0 relevant to the printer. If you do not have the original CD download the appropriate suite from Brother Solution Center.When you install the software you will be asked to choose USB, or Local Network. You can always install the USB and connect the printer to the calculator through USB. Different installations for different connection types (USB, LAN)After you configure the software, you can open the Control Center 3 software and use the fax.To be able to fax, you need to connect a telephone cable to the port marked line. After you do try pressing the unhook button. If connection to the phone line is correct you will hear the tone.The MFC can fax without being connect to a computer, just the phone line.
7/31/2012 4:19:22 AM • Brother MFC-210C... • Answered on Jul 31, 2012
MFC-210C manual
Hi!
Get it from here...
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
4/6/2011 10:53:28 AM • Brother MFC-210C... • Answered on Apr 06, 2011
My printer si saying unable to initialize, is it
You might have to uninstall the printer restart your computer then reinstall your printer click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device hope this helps dont forget to vote
2/26/2011 11:12:33 PM • Brother MFC-210C... • Answered on Feb 26, 2011
What plugs do i need to hook up my printrt to my
Follow these steps :
1.1
Position your printer. If you have a laser printer, allow a few inches of space on all sides for ventilation. Ink-jet printers don't require ventilation.
2.2
Buy a bidirectional, IEEE 1284-compliant parallel printer cable. (Printers rarely come with cables. See "How to Buy a Printer Cable," under Related eHows, for more information.)
3.3
Shut down the computer, but leave it plugged into the surge suppressor.
4.4
Compare the connectors at the opposite ends of the cable.
5.5
Attach the 25-pin end of the cable to the parallel, or printer, port on the computer. (The plug will go in only one way.)
6.6
Tighten the hand screws securely.
7.7
Connect the other end of the cable into the printer's socket.
8.8
Latch the retaining clips (on most printer ports).
9.9
Plug the power cord into the printer and into the surge suppressor.
10.10
Turn on the printer.
11.11
Install cartridges according to the printer manufacturer's instructions.
12.12
Turn on the computer.
13.13
Install printer driver software according to the manufacturer's instructions.
14.14
Add the printer to the list of printers your computer recognizes (see "How to Add a Printer," under Related eHows). On a Macintosh, just select the new printer in the Chooser.
10/29/2010 4:50:53 PM • Brother MFC-210C... • Answered on Oct 29, 2010
Where do I hook up from the 210 to my computer?
They usually come with a USB cable. Connect the square end into the printer, and the flat end into one of the many ports on your computer.
4/3/2010 7:47:36 PM • Brother MFC-210C... • Answered on Apr 03, 2010
I have installed a new ink cartrage but the
Restart the computer. Turn off the printer. Turn the printer back on after the computer is fully started.
3/29/2010 2:24:15 AM • Brother MFC-210C... • Answered on Mar 29, 2010
Printer is making a loud grinding noise and
clean your printer from dust at two corner of the cartrage rod & put oil.
3/17/2010 1:54:27 PM • Brother MFC-210C... • Answered on Mar 17, 2010
It is not cleaning or printing
check mains transformer
3/11/2010 12:21:27 AM • Brother MFC-210C... • Answered on Mar 11, 2010
How do I hook up my mfc to my computer there is no
The ends are not the same on the A-B USB cable that you require. The smaller end no doubt will plug into the back of your printer somewhere. I hope..
3/7/2010 7:29:29 PM • Brother MFC-210C... • Answered on Mar 07, 2010
Copier will not work
Plug it in.
2/17/2010 2:49:59 AM • Brother MFC-210C... • Answered on Feb 17, 2010
How do i scann something and send it as a email?
If you have a Windows operating system on your computer (XP Vista, etc.,) place the document you want to scan on your scanner and turn your scanner on.
Then,go to:
Start > All Programs > Accessories > Paint
1) When the Paint program opens, (on the toolbar at the top of the program) click on, 'File' then scroll down and click on, 'From Scanner or Camera'.
2) Click on the icon for your scanner, then click, 'OK'.
3) Click, 'Scan'.
4) The document will be scanned and imported into the paint program automatically.
5) Then, (again) click on, 'File' (in the toolbar) and select, 'Save As' > (name your document) > select a file on your computer to save the document in (for example: Pictures).
6) Log into your email account.
7) Click, N
'New' or 'Compose' (whichever applies) and compose (type) your email.
8) Then locate the word or option that reads, 'Attachment' (which will usually have a small icon of a paperclip by the side of it) and click on the word 'Attachment'.
(a window will open)
9) Find the button in the window that reads: 'Browse'. Click on the 'Browse' button and locate the file where your scanned document was saved > and click on it. (this should attach the file to your email.)
For large documents and files, if your email provider doesn't allow large documents or files, you can email them with yahoo. After composing your email, look to (your) bottom left of the page you are going to email and click on, 'Attach Large Files'
- you'll have to click, 'Accept the first time' then attach your file and click, 'Send'. That's all there is to it.
2/6/2010 2:01:18 PM • Brother MFC-210C... • Answered on Feb 06, 2010
Brother MFC-210C All-In-One Printer Logo
36 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
installed new ink cartrage but
  • Office Equipment & Supplies
