20 Most Recent
Thermador RDF30 Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
I can't read the oven
I could not find a panel for your model.
We have used http://fixyourboard.com/ to repair control boards that were NLA.
Check with them to see what it would cost to rebuild the one you have.
My RDFS30 left front burner
Hello
& Welcome to FixYa
The
problem is with the jet holder, first try to clean it. After that is cleaned
and the problem is still there then clean the burner and the tubing/valve. You can check the parts images here. After that is cleaned & if the problem is still there then the spark module
needs replacement. Please get back to me if you have any other questions.
Kevin
Thermador 30" Dual-Fuel Range 0FF error
Make sure there is proper electrical power going to range. Then check your kitcen circuit breakers or fuse box in your house, then reset the oven controls.
LOL look what i found, a CHILD LOCKOUT FUNCTION-- check this out
TO SET CHILD LOCKOUT
Press and hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF appears in the
display (approximately 6 seconds).
TO CANCEL THE CHILD LOCKOUT
Press and Hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF disappears
from the display (approximately 6 seconds). Mode selections will now be available on the control panel.
looks like someones could have been playing with the buttons and locked you out..
Let me know what happen.........................please rate this
Thermador Oven Professional PODC302 clock runs fast.
Hello Mark,
Unfortunately I've seen my fair share of these and yes the problem is internal of the control. If you know anyone who is pretty handy with electronics or the like, they may be capable of rebuilding your's, but otherwise it needs to be replaced.
On a side note. If the warranty period literally just expired you should double check your owners manual. Often timers and many "solid-state" components come with an "exceptional warranty" of up to 5 yrs. Depending on what your specific manual states, but it's worth a look.
Also I would encourage you to phone B/S/H customer support and express a grievance, it sometimes will result in them picking up the cost of the part or labor or if lucky, both.
It's not likely what you wanted to hear about the control but it's the reality. Hope you found this helpful to you. Thanks for visiting "fixya" today and please take a moment and rate the information I provided here for you.
Good luck.
macmarkus :)
I am quoting above because I really need help. "When I push any of the function buttons on the oven console
(Timer, Bake, Broil, Clock) the display shows 0FF in red next to the
clock. The oven will not turn on and the timer will not work. I can not
find any troubleshooting information on this problem. The oven is a model RDDS30V. Any help would be greatly appreciated!"
Oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Replacing the TRD sensor in a Thermador double oven.
Please look on page 40 of the manual for the Thermador SMW272 B Service Manual to find specific directions for removing the sensor. You can text "SUPPORT" to 53730 for quick access to such documents or call 1 (800) 735-4328 to speak to Thermador.
Thank you.
2/24/2023 1:20:05 AM •
Thermador...
Answered
on Feb 24, 2023
