20 Most Recent
Android Recovery Stick - Retrieves Deleted Text Messages & More--brand Questions & Answers
Can I see deleted text messages
Here I would like to recommend you the Android Data Recovery, which is designed for recovering all the deleted as well as lost and formatted messages as well as contacts, photos, videos from Android Devices.
either you can go for.::
http://www.data-rescue-tools.com/wondershare-data-recovery-for-android.html
How do I unlock my android vortex hd65 I need the me number how do I get it?
To find the IMEI number of your Android Vortex HD65, you can typically locate it in one of the following ways:
1. Dial *#06#: You can dial *#06# on your phone's keypad, and the IMEI number will be displayed on the screen. or
2. Check the phone's settings:
Go to Settings
go to About phone
Look for the "Status" or "Phone status"
you should find the IMEI number listed.
3. If you have the original box or documentation that came with your phone, the IMEI number may be printed on a sticker or label.
4. If your Android phone has a removable battery, you may find the IMEI number printed on a sticker underneath the battery.
Good Luck
Smart phone touch screen TOO sensitive
I'm sorry to hear that you are having trouble with your phone during calls. It sounds like there might be a couple of different issues at play here.
Firstly, it is possible that you are accidentally touching the touchscreen with your ear, jaw, or cheekbone, which can mute or end the call. This is a common problem, especially for those who are new to using smartphones. One solution is to try holding the phone a little further away from your face or use a hands-free headset or earbuds to keep the phone away from your face.
Secondly, it is true that many phones have a feature that locks the touchscreen during a call to prevent accidental touches. However, this feature may not be enabled on your specific phone or may not be working properly. To check if this feature is enabled on your phone, go to your phone's Settings app, select "Accessibility," and look for an option called "Power button ends call" or something similar. If this option is enabled, it should lock the touchscreen during calls. If the option is not available or not working, you may need to contact your phone's manufacturer or your carrier for assistance.
Lastly, if neither of the above solutions work, there may be an issue with your phone's hardware or software that is causing the problem. In this case, it may be best to take your phone to a professional for diagnosis and repair.
I hope this information helps you resolve the issue with your phone during calls.
Aftron AFLED4310 Smart tv
If your TV is still not working after disconnecting it from power and waiting a few hours, then it is likely that the files that were deleted were essential to the TV's operation. In this case, it is likely that you will need to have the TV serviced by a qualified technician.
Tv tap error kodi
You can restart and/or shut off your phone for a while. You could also take out the battery for a while, if you can.
My android heos app is not finding my maranta receiver
If your Android HEOS app is not finding your Marantz receiver, there are a few things you can try:
- Make sure that your Marantz receiver and your Android device are connected to the same Wi-Fi network.
- Check that the HEOS app is up to date by going to the Google Play Store and checking for updates.
- Try resetting your Marantz receiver by unplugging it from power, waiting a few seconds, and then plugging it back in.
- Check that your Marantz receiver is set up properly. Refer to the user manual for instructions on how to set up the receiver.
- If none of these steps work, try turning off your router and mobile device and then restarting them.
- Try disabling and re-enabling the wifi settings on your android device
- Check if the latest firmware update is installed on the Marantz Receiver
These steps should help resolve the issue. If the problem persists, you may need to contact Marantz support for further assistance.
Why is my android stuck on 'select boost mode'?
There are several reasons why your Android device may be stuck on "Select Boost Mode." Some possible causes include:
- Insufficient storage: If there is not enough storage on your device, it may not be able to complete the boost mode process.
- Corrupted system files: If the system files on your device have become corrupted, it can cause the device to get stuck in boost mode.
- Software bugs: Some software bugs can cause your device to get stuck in boost mode.
- Malware or Virus: If your device is infected with malware or a virus, it may cause it to get stuck in boost mode.
- Hardware problems: Some hardware problems can cause the device to get stuck in boost mode.
To resolve this issue, try booting the device into safe mode, clearing cache and data of the device, factory resetting the device or taking the device to a professional for repair. If the problem persists, it may be best to contact the device's manufacturer for further assistance or warranty service.
How do I link my Android phone to my 2019 CRV screen?
To link your Android phone to the screen in a 2019 Honda CR-V, you will need to use the car's infotainment system, which is called HondaLink. Here are the steps to link your phone:
- Turn on the ignition of your CR-V and make sure the infotainment system is on.
- On your Android phone, go to the "Settings" menu and enable "Bluetooth."
- On the infotainment system, select "Phone" and then "Settings."
- Select "Add Device" and wait for the system to search for available devices.
- On your Android phone, you should see the CR-V listed as a available device to pair. Select it and enter the passcode provided by the CR-V infotainment system.
- Once the connection is established, you should be able to control your phone's music, make calls and send text messages through the CR-V's infotainment system.
You may refer to the CR-V's owner's manual for specific instructions on how to use the HondaLink system as it may vary depending on the model, trim and region.
