20 Most Recent
Lexus 1999 2000 2001 2002 2003 Is200 Is300 Is350 Horn Questions & Answers
How to remove and Install Headlight Lens?
hello
u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store
for free
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
Tighten power steering belt is200
My standard answer for this type of question is that you should purchase a haynes or chiltons manuel for your vehicle, you will find a lot of very good info about many things as well as tips for repairs that will save you time.
These can be purchased from most auto supply stores or for a little less money on ebay.
My car 2001 lexus is200 has no power in the ignition, dashboard and interior
Fusible link directly off battery? Usually on the positive cable. Feel the wire if not visibly burnt or broken, Use fingernail tips and "feel" for the break. Also relays in the relay box, some are same as ignition, power sources ect. Can take off wipers or some other relay that is not essential and test.
Radio turns off by itself.
if the two wires touched or touched the body it will cause a short, since everything is connected as a system this could very well cause all the problems. could also be a bad ground wire.
How to get more low end power from lexus is200 auto
have a talk with the service centre for lexus vehicles and see if you can have the cpu reprogrammed to give more fuel at a lower rpms. failing that you may have to have a new chip fitted at a speed shop and have it reset to what you want.
Handle mechanism for lexus is200
The rod should have a plastic clip on the end to attach it to the door parts inside the door it should attach by the rod coming from the inside handle
