20 Most Recent Thermador 31 in. SGSX304Z Gas Cooktop Questions & Answers
SGCS304RS The two left burners work. The two right
The regulators are clogged and so there is no gas flow due to this. use a good brush to clean the burner tops so as to get the mixture of gas /air correct. Use pressurized air to clean the valve, clean the JETS and reset.
6/14/2011 5:01:58 AM • Thermador 31 in.... • Answered on Jun 14, 2011
Thermador CET366FS Cooktop. I need some instruction on how to replace the control module.
Thermador are top of the range appliances and they don't expect you to repair them yourself, you call for a service engineer. Service manuals are hard to come by. There is a service manual for a wall oven and the control panel may be similar. They look to have mounting clips. The buttons are proximity detectors, so not conductive. https://www.google.com/search?q=thermador+cet366fs+cooktop+service+manual+pdf They are made by Whirlpool so this might help. Wherever you got the board from should supply the instructions on the same way that Repair Clinic do. ..
10/6/2023 11:38:48 PM • Thermador... • Answered on Oct 06, 2023
Some of the control knobs on my Thermador Rangetop PCG366W sink all the way in so that you can't see the writing on the knob, is that normal? If not, is there a fix for it?
Burners Do Not Start Hand on burners The Burners Do Not Start There are several solutions for this problem: The main gas supply may not be turned on. Make sure it is turned on. Check the power supply and make sure the unit is plugged in and the circuit breaker has not tripped. Make sure the burners are properly positioned. The igniters may be dirty. Carefully wipe the igniters with a cotton swab dampened with water after they have cooled down. Gently scrape the soil off with a toothpick. Avoid exposing the igniters to excessive water as a damp igniter may not light up. Remove any lint that may remain after cleaning. The ignition will be quicker if a cooking pan is on the grate. Ignite the gas at full and once alight, turn it down to around 50%. It should lock on within 6 seconds. Does the burner click when the burner knob is in the ON position? If yes, you may have a wiring issue at the outlet that the appliance is connected to. Turn off the main gas supply and contact a qualified electrician to fix this. Does the burner click when the burner knob is in the OFF position? If yes, check for the following: 1. Check to see if the burner cap is properly placed and the igniter is not wet or dirty. 2. Check to see if the regulator supplied with the unit is installed properly. The arrow on the regulator should be pointing to the appliance. Please call a professional installer
1/16/2023 6:59:14 PM • Thermador... • Answered on Jan 16, 2023
Thermador induction cooktop CIT304E error code U 24
Question moved form Water Heaters to Thermador Cooktop There is an F24, but not a U24 F24 Touch input key stuck Replace power relay board, and touch panel https://www.google.com/search?q=Thermador+induction+cooktop+error+code+U+24 ..
12/26/2021 8:00:43 PM • Thermador... • Answered on Dec 26, 2021
Two electric burnings on thermador cooktop not working. Can they be repaired
Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges,the oven temperature sensor is the part thatregulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meterbut will need to know the correctresistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check foroverheated wires or faulty terminals first.Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
  1. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.(Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
  1. On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
  1. Set yourmultimeterto ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
  1. Repeat the step above for the terminals "L2" and "H2".
  1. If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
  1. With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
  1. A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens usean electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. element burner testing range element-short.2-undefined-undefined-0_3.gif element burner 0-undefined-undefined-2_1.jpg infinte switch_noheat_03-undefined-undefined-5_1.jpg infinite switchs stove-undefined-undefined-9_0.jpg
3/17/2020 7:09:00 AM • Thermador... • Answered on Mar 17, 2020
Two burners on thermador cook top turn off by themselves
It is common for electric coils on a range top to click/on/off. They are suppose to reach a certain heating range and when satisfied, they go neutral and when the demand for heat is needed, they become energized again.
2/9/2018 6:25:37 PM • Thermador... • Answered on Feb 09, 2018
Have a thermador psc364gdzs the spark does not work for the gridle
The spark module is in the ignition circuit for the gas burners. When a burner control knob is turned to the Lite position, it provides voltage to the spark electrodes on the gas burners. If the spark module fails to provide the electrodes with voltage, then it should be replaced.
8/29/2017 11:38:38 PM • Thermador... • Answered on Aug 29, 2017
Cook top not igniting
Find the gas interlock, keeps gas from escaping when trbl with burners...You need to follow procedure for relighting which entails preheating interlock.
5/15/2017 12:52:06 AM • Thermador... • Answered on May 15, 2017
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html Thermador Stove Burner Won Light Burner on Thermador cooktop won light
3/22/2016 9:07:24 PM • Thermador... • Answered on Mar 22, 2016
I need to find a replacement for the cooktop knob for SGCS304RS. Thermador, ebay, amazon doesn't have it. Where else can I find it?
Hi, I found 8 of them in black part number 00414835 from a company called Marcone Appliance Parts 800-821-0244. Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
3/13/2016 12:21:45 AM • Thermador... • Answered on Mar 13, 2016
Do the burner control knobs just pull off? Mine refuse to budge.
SYLV,THERE MIGHT BE SET SCREWS HOLDING THE KNOBS ON? CHECK CAREFULLY MABE WITH A FLASH-LIGHT.THANKS
1/25/2016 10:32:43 PM • Thermador... • Answered on Jan 25, 2016
Where is the thermostat that keeps the bake element from working
Usually it will be on the back of the oven, behind panel, or on top. very rear on the bottom.
6/20/2015 11:37:16 PM • Thermador... • Answered on Jun 20, 2015
Thermador 31 in. SGSX304Z Gas Cooktop Logo
4 questions posted
Top Thermador Cooktops Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Thermador Cooktops
  • Thermador Cooktops
Most Popular Question
sgcs304rs two left burners work two
  • Cooktops
