20 Most Recent Asrock ConRoe865PE Motherboard Questions & Answers
Conroe presler fsb 1066 conroe865gv
unkowndevise
10/23/2013 5:02:50 PM • Asrock... • Answered on Oct 23, 2013
Will conroe 865pe support windows7 ultimate
No only win xp and xp 64 bit.Here is the home page:http://www.asrock.com/mb/Intel/ConRoe865PE/?cat=DownloadGood luck
11/20/2012 5:46:48 PM • Asrock... • Answered on Nov 20, 2012
Grapics driver
gotot asrock.com and there you can download the drivers for that motherboard. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
11/9/2009 4:08:27 PM • Asrock... • Answered on Nov 09, 2009
Cant install a Q6600 CPU
Your problem is about the BIOS, you need one that would allow it to recognize that processor - get it directly from Asrock and reflash your board.
10/25/2009 5:12:09 PM • Asrock... • Answered on Oct 25, 2009
Intel E5200 Freq Problem with Asrock ConRoe865PE
The new E52XX runs according to the pc's requirements. see at the particular time you were checking the spec the pc needed only 1.19Ghz of performance to run the programs. hence the there was no need for it to run on full capacity. this is one feature that reduces power consumption.
http://processorfinder.intel.com/details.aspx?sSpec=SLAY7
right click on my computer & see what the CPU spec is on the General tab.
3/25/2009 2:33:42 AM • Asrock... • Answered on Mar 25, 2009
2answers
Drivers
find the driver at www.driverguide.com....register you first before browse your drive sir....
12/7/2008 1:34:48 AM • Asrock... • Answered on Dec 07, 2008
Asrock h110 disable on board video using cards for mining only
real asrock mobo told ,just the intel chipset code H110the bios controls that in bios disable iGPU. no cpu told either as some have no igpu at all.like xeons, and some mobo can run both i3+ and zeons.see this search at asrocksee how your post has no real clues?https://www.asrock.com/support/index.asp?Model=h11029 mobo made based on only intel chipet.
5/7/2022 4:02:49 PM • Asrock Computers... • Answered on May 07, 2022
Asrock h110 disable on board video card
double posted you?of 29mobo not one told.https://www.asrock.com/support/index.asp?Model=h110the bios page,labeled, igpu (disable /enable ) is there.some mobo allow zeon here with zero igpu.but not yoursthey make h110 ,mobo just for useless now, bitcoin mining.watch the netflix movie how the blocked mining,then save moneyalso learn what ROI is?
5/7/2022 3:59:28 PM • Asrock Computers... • Answered on May 07, 2022
3answers
No display on my Asrock P4I45GV
Check Ram and fun if not properly installed
5/7/2022 2:12:39 PM • Asrock Computers... • Answered on May 07, 2022
2answers
Asrock G31M-S No Display/not Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO. If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
5/7/2022 1:13:35 PM • Asrock Computers... • Answered on May 07, 2022
MY ASROCK MOTHERBOARD OUTPUT DEVICES IS NOT WORKING
3 post all the same mobo and all 3 same reasons. and all 3 same answers. zero no I added one, coin cell is dead at 7 years, you are 2004 to 2018 late to the party. 14 year old battery is 2 times spec life. for sure.
12/29/2021 4:42:52 PM • Asrock Computers... • Answered on Dec 29, 2021
Factory reset windows 8.1 error
Wipe the hard drive and do a clean install, not repair.
9/21/2017 1:33:46 AM • Asrock Computers... • Answered on Sep 21, 2017
This is my system, -K10N780SLIX3 wifi Mobo -Gtx
swapping out parts, try with different power supply pull the ram reseat it maybe one at time. different memory slots. change one part at a time with good working part, never assume any part is good.
4/19/2017 12:36:24 AM • Asrock Computers... • Answered on Apr 19, 2017
Asrock ConRoe865PE Motherboard Logo
Popular Tags
11 questions posted
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Asrock Computers & Internet
Most Popular Question
intel e5200 freq problem asrock
  • Computers & Internet
