20 Most Recent
Intel DG965WH Motherboard Questions & Answers
Where to connect pc spkr on dg965wh board thats
front panel header pin assy,go to intel website and download the manual for that model,it will tell you all jumper settings and pin settings,it might be under discontinued models,it will be labeled SPK
Will not turn on. new power supply.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
No sound
if you mean that you dont have a sound card
you might have to get a portable usb sound card if you mean dont have a sound card installed or
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Motherboard and ram..
DG965WH Board works well with 533 RAM, but is very finicky about 800, if you use 800, use only what is recomended.
I used kingston KVR533D2N4K2/2G with good luck on 4 motherboards.
You can try it, but watch for crashes and stabilty issues, if it has issues, remove it.
No boot
Check to make sure you don't have any extra standoffs under the motherboard that may be shorting it out.
Audio on motherboard not working.
If the southbridge chipset is intact and operational, either physically open the case and see if you can visually see the chip set #,
or my favorite, download and run
everesthome,
click on + by motherboard
click on chipset
click on southbridge in right column,
google the chip set drivers or the audio control set drivers
or click on the "ask me " under my id .and give me the #'s I'll link you to the updated drivers.
Boot
CORRUPTED BIOS
Reprogramming the BIOS That depends on your motherboard Model. It should correspond to your BIOS Model.
Download the Motherboard's BIOS file usually in a Zip file then the contents are .bin files. Then use the
BIOS manufacturer's EPROM Programming tool. Which usually comes with a user manual or guide on how to's.
Just follow its examples.
Hope this helps
If you are having trouble with Newly bought items save your self from headaches by returning them and
demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Motherbord driver
you need to find a linux distribution which supports installation into sata. or a version of your current distro with sata support check the distros website and forum for support.
CD DVD NOT RECOGNIZED
In the BIOS, set the disk controller to Legacy mode if mobo doesn't recognize IDE CD/DVD Drives.
Wont Install
Ofcourse you will need it..Get your DVD writer's brand and model...
