20 Most Recent ASUS P5W DH Deluxe Motherboard Questions & Answers
Hi. I have just got back my pc after a refit,
Sounds like Mobo faulty Pal.. Skt 775 old now getting on
9/3/2017 1:14:34 PM • ASUS P5W DH... • Answered on Sep 03, 2017
0answers
Asus p5w continous beeps from internal speaker
Hello here is the homepage:http://support.asus.com/Download.aspx?SLanguage=en&m=P5W%20DH%20Deluxe&p=1&s=22A component on the mainboard, could have a defect.This could be a ram module overheating, or the power supply is too small, or overheating.The mainboard supports 4 x 240-pin DIMM sockets support max. 8GB DDR2 800/ 667/ 533 ECC and non-ECC memory.Try to blow the pc out for dust with compressed air, and update the mainboard drivers, and the bios to the latest version. And try to renew the thermal paste, between the cpu and the cooling element.Or simply the mainboard has a internal defect.Good luck
2/10/2013 2:17:09 AM • ASUS P5W DH... • Answered on Feb 10, 2013
Is the ASUS P5W DH Deluxe Motherboard stil for sale, mine is broken. Or is there one that is compatible?
Try www.ebay.com input particulars to see if you can come up with a match.
9/17/2012 9:53:05 PM • ASUS P5W DH... • Answered on Sep 17, 2012
My asus p5n-E sli motherboard
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function the beeps are post pre operating system searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error hope this helps you
8/28/2011 2:01:04 AM • ASUS P5W DH... • Answered on Aug 28, 2011
I had a static discharge
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
5/8/2011 10:08:32 PM • ASUS P5W DH... • Answered on May 08, 2011
I HAVE UPGRADED TO WIN7
If you go to this homepage:
http://support.asus.com/download/download.aspx?modelname=P5W DH Deluxe&SLanguage=en-us
You can download the driver for Vista but there is no option for win 7
11/14/2010 1:07:39 PM • ASUS P5W DH... • Answered on Nov 14, 2010
Doesnt detect dvx100 panasonic camcorder
you may need to put the camcorder into a special mode for the PC to detect it or you may have to install the drivers for the camera. Check on the panasonic website for the drivers and the manual as this will tell you what and how to set the camera for PC connection.
3/14/2010 1:42:49 PM • ASUS P5W DH... • Answered on Mar 14, 2010
tip
Beep Code Explained
Thanks to Transcend Technical Support for this great Brief of understanding beep codes that is found here
This is a long post and it may be truncated at the bottom. If so, use the link above to go to the Transcend web site where these are found
1.General POST (initial system boot) BEEP Codes
If you do not know the BIOS manufacturer, the following will be the general Beep codes:
• 1 Long and 1 Short Beep ?Bad Motherboard
• 1 Short Beep and nothing else happens ?Disk Drive/Video Related Problems
• 1 Long and 2 Short Beeps ?Bad Video Card
• 1 Continuous Beep or Non-stop short Beeps ?Bad Power Supply
• 3 Short Beeps - Bad Memory
2.American Megatrends Inc. (AMI) BEEP Codes
• 1 Beep - Memory refresh timer error.
Reseat the memory, or replace with known good modules.
• 2 Beeps - Parity Error
• 3 Beeps - Main memory read / write test error.
• 4 Beeps - Motherboard timer not operational
• 5 Beeps - Processor Errors
• 6 Beeps - Keyboard controller BAT test error.
• 7 Beeps - General exception error.
• 8 Beeps - Display memory error.
If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
• 9 Beeps - ROM checksum error
• 10 Beeps - CMOS shutdown register read/write error
• 11 Beeps - Cache Memory Bad
Beeps 4-7, 9-11
Fatal error indicating a serious problem with the system. Consult your system manufacturer.
Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
?If the beep codes are generated even when all other expansion cards are absent, the motherboard has a serious problem. Consult your system manufacturer.
?If the beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning add-in card.
3.Award Bios BEEP Codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
• 1 Long, then 2 Short Beeps: Video error
Explanation: The BIOS is unable to access the video system in order to write any error messages to the screen.
Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
• 1 Long, then 3 Short Beeps: Video error
• Continuous Beeping: Memory or video problem
Explanation: The system is producing constant beeping in no specific pattern, or a fast "ringing" sound.
Diagnosis: This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
• Other Beep Codes
Explanation: You have encountered an Award BIOS beep code I do not have documented.
Diagnosis: Award says that any beep patterns other than "one long followed by two short" are likely problems with the system memory. However, of late they have started adding other beep codes to their systems as well.
4.Phoenix BEEP Codes
• 1-1-3
Explanation: Your computer can't read the configuration information stored in the CMOS.
Diagnosis: Replace the motherboard.
• 1-1-4
Explanation: Your BIOS needs to be replaced.
Diagnosis: Got to your motherboard manufacturers web site and download the new Bios.
• 1-2-1
Explanation: You have a bad timer chip on the motherboard.
• 1-2-2 or 1-2-3 or 1-3-1 or 1-3-3 or 1-3-4 or 1-4-1
Explanation: Motherboards is bad.
• 1-4-2
Explanation: Some of your memory is bad.
Diagnosis: Go to Basic Trouble Shooting
• 1-3-1
• 2-_-_ Any combination of beeps after two
Explanation: Some of your memory might be bad.
• 3-1-_
Explanation: One of the chips on your motherboard is broken.
• 3-2-4
Explanation: Keyboard controller failure.
Diagnosis:
• 3-3-4
Explanation: Your computer can't find the video card.
Diagnosis: Is it there? If so, try swapping it with another one and see if it works.
• 3-4-_
Explanation: Your video card isn't working.
Diagnosis: Replace Video Card.
4answers
Computer powers on but then turns off after a few seconds
I know this is a late response but someone might have this similar issue which is generally caused by a faulty power switch on the case of the computer. The switch is stuck in the pressed or active position so when you power the computer the switch still being depressed or faulty turns the computer right back off again and you're stuck in this loop. The best way to identify if this is the issue is to remove the power shunt from the jumper then use a screw driver to jump the power connections that would turn the computer on... if it stays on the switch or entire case needs to be replaced whichever is easier
1/1/2010 6:26:52 PM • ASUS P5W DH... • Answered on Jan 01, 2010
Keep getting "unable to decompress the file"
Download the file, then unzip it (assuming that's what you mean by decompress). Then use the ASUS utility to update the BIOS.
10/14/2009 11:24:01 PM • ASUS P5W DH... • Answered on Oct 14, 2009
1 long continuous beep
Sounds like a memory issue to me. Power off the Computer. Remove all the memory and add 1 memory module. Power up to see if still the problem. If so, power down, remove the module and go through the same process with the other module to see which module is the problem. Hope that helps.
7/16/2009 8:22:28 PM • ASUS P5W DH... • Answered on Jul 16, 2009
Hey you have the driver for Asus p4vbx mx ?
here you go: http://support.asus.com/download/download.aspx?SLanguage=en-us
7/10/2009 10:17:13 PM • ASUS P5W DH... • Answered on Jul 10, 2009
Continuous beep and windows crashes
Check the memory, My machine is currently doing this.
3/7/2009 12:34:55 PM • ASUS P5W DH... • Answered on Mar 07, 2009
3answers
Asus p5w DH Deluxe: updated to new bios 2704 now only black screen on boot up
After a bios update like this one, remove the battery from the motherboard and remove the power cable from the power supply. Leave out for a few minutes, then replace the battery and the plug and try to reboot.
8/10/2008 5:37:12 PM • ASUS P5W DH... • Answered on Aug 10, 2008
No Video Output
You mentioned you placed "another" PCI-E card into PCIEX16_2 slot.
You need to remove the video card from the PCIEX16_1 slot first & try the second video card in PCIEX16_1 slot. Page 2-4 in manual.
Boot the system & see if you have video. If yes than the other PCI-E video card has an issue.
Just adding a second card will not boot.
You do want to replace the video in slot 1. This way you do not need to make any changes in you're bios or add the additional power (Which is required to run both at the same time). (Kind of hard to get into the bios when there is no video display).
Luck!
Mike
7/6/2008 8:29:25 PM • ASUS P5W DH... • Answered on Jul 06, 2008
Probem with Asus P5W DH waking back up
Do you have a modem plugged into phone line - is a signal on phone line causing it (unplug phone line cable to try that).
Could be faulty power switch on front of computer where the contacts are only a hairs breadth apart and the slightest movement/vibration causes it to contact (try this by disconnecting those two wires from the motherboard
I'd try disconnectng any communication cables from the computer first. That would be LAN and Modem cables. If it still restarts, disconnect the keyboard and power down the PC. If it still restarts, then power down again before it is fully off, remove the mouse. If it still does it get a priest to do an exorcism
12/16/2007 2:01:26 AM • ASUS P5W DH... • Answered on Dec 16, 2007
CPU errors
i have had this problem myself with asus board before .I flashed an update to bios and it sorted it out u could try this
by the way r u trying to overclock? because wrong memmory settings can cause this to
12/15/2007 11:04:13 PM • ASUS P5W DH... • Answered on Dec 15, 2007
Long beep from the power supply
remove everything from the mother board except cpu & memory the power supply does it beep now? if so remove memory try again.
12/14/2007 7:18:08 PM • ASUS P5W DH... • Answered on Dec 14, 2007
ASUS P5W DH Deluxe Motherboard Logo
24 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
  • Computers & Internet
