20 Most Recent
Traeger Industries BBQ100 All-in-One Grill / Smoker Questions & Answers
Err message on my Traeger
I had the same problem; I talked to Traeger talked to their rep and he walked me through fixing the problem. There are two wires leading from the temperature probe, these lead back to the thermostat digital controller. With the unit unplugged, unscrew the two screws holding the temperature controller in place. Slowly and carefully pull out, and check that both wires are running into the controller. If either is disconnected, strip a little more wire off the loosened wire, put back in hole and tighten the wire back down. That was the trick for my grill. Reassemble and reconnect power and test it out.
8/22/2019 5:51:01 PM •
Traeger...
Answered
on Aug 22, 2019
Why won't the auger stop on my traeger
That's a hard question to answer without more detail. When does it keep going? When you're cooking? When you turn it off? When you first fire it up?
6/2/2019 5:37:44 PM •
Traeger...
Answered
on Jun 02, 2019
Traeger grill get to hot on smoke
If you're cooking when it's hot outside, it's hard to maintain low temperatures. In the heat of summer, I have to tend my grill continually opening and closing the lid to keep the temperature down to my cooking temp of 180. That, of course, lets the smoke escape. If it gets too hot when the temperatures are moderate, i.e. 60s and 70s, the augur may be dumping too many pellets into the fire pot and need realigning. I suggest you contact Traeger customer service at
http://www.traegergrills.com and see what they suggest.
12/4/2014 11:00:32 PM •
Traeger...
Answered
on Dec 04, 2014
Traeger grill not smoking
This is a common complaint about Traeger grills. Some people have resolved it with smoke pipes which contain pellets that smolder during the cooking process.
Others use different pellets than Traeger pellets but they void their warranty when they do. For me, Traeger pellets seem to put out enough smoke at the low temperatures I use (less than 200 degrees) but if I get above 200, the smoke goes sway.
When I cook pork shoulders, I try to keep the temperature at 180. In ideal conditions the Traeger will fluctuate between 160 and 200, averaging 180. If I can maintain this low-slow cooking temp-speed, I get a good smoke ring and decent smoke flavor.
If I get above 200, I lose much of the flavor but usually have a smoke ring though not as intense as at the lower temps. There are lots of conversations about this on blogs at the Traeger website and at the Pelletheads website.
12/4/2014 10:33:37 PM •
Traeger...
Answered
on Dec 04, 2014
My trager grill is smoking a lot in the pellet hopper
That could mean that pellets in the augur have caught fire and it can work its way back to the hopper. Then you really have a problem. Are you sure the fan is running?
You should be able to hear it. The fan helps keep the heat from working its way into the augur. If it's not running, you should also be having trouble controlling the temperature.
Traeger has specific instructions on its website for testing various components including the fan and customer support can assist you with this problem.
Here's a link to the Traeger website:
http://www.traegergrills.com/. I'd suggest you get in touch with them ASAP because you definitely don't want to deal with burning pellets in the hopper.
12/4/2014 10:03:42 PM •
Traeger...
Answered
on Dec 04, 2014
Grill wont fire up
From Traeger:
Why won't my Grill Ignite?
- If your grill is plugged into an electrical outlet with a GFI (ground fault interrupter) plug, chances are the hot rod has absorbed or been exposed to too much moisture and is leaking to ground causing the plug to trip.
- Open your cooking chamber lid, remove cooking grill, angled drip pan and U-shaped firepot cover. Is there ash build up in the firepot and/or around the firepot? If so, this needs to be cleaned out. The ash is choking out the fire.
- Check the fuse on the back of the control board. To do this, first UNPLUG the grill from the electrical outlet. Then, unscrew the control board and look at the fuse-is it blown or not?
- If the fuse is good, check for power by switching the colored plugs first. Unplug the purple plug and the orange plug. Plug the purple plug into the orange plug. Now plug the power cord back into the electrical outlet and turn the grill on. Does the induction fan operate? If so, you will need a new hot rod and fuse. If not, you will need a new control board. Unplug the purple from the orange and reconnect the plugs together to their correct color plug.
- Always start your grill on the SMOKE setting.
5/3/2014 4:36:37 PM •
Traeger...
Answered
on May 03, 2014
I'm getting an "Err" message
Remove your grill, inner shield and outer dip plate from the Traeger. Start the Traeger in smoke mode. Observe to see if the blower fan is working. Is the auger turning? Are the pellets dry? Condensation can make the pellets swell and cause plug ups.
8/16/2010 1:03:58 AM •
Traeger...
Answered
on Aug 16, 2010
