20 Most Recent
Tyan Toledo i3010W (S5197G2NR TOLEDO I3010W) Motherboard Questions & Answers
Sys Init Error - Halt - But I want it to skip All Errors
darian69, windows did not setup correctly. Double check all data cables & power cable connections. (Tight fits).
(This is not an uncommon error). Please download the manufactures drive utility software for a bootable floppy disk or bootable cdrom disk. Test/check & setup the drive, (formatt). Than install windows. Once installed, turn on windows firwall & install nic driver software. Run windows update. Check for hardware updates & install. This should fix the system halt.
Please let me know if this stopped the error message.
Mike
Error code d4
There is a conflict in shadow ram.
Check the add-on cards.
It may be necessary to disable the BIOS shadow into RAM in order to make space for the other cards ROM
Red light 03 motherboard s5512wg
This error is "Initial Superio_Early_Init switch"
This error occurs when The first memory module is bad or the BIOS is corrupt.
Exchange RAM.
If that does not work, Reset the BIOS by removing the battery for two minutes
If that does not work, replace BIOS; or motherboard.
How do i reset the password on a Tyan m3296 SMDC
contact Tyan and request support, just say that the hardware was in a machine you were given. It might be that that there is a generic password built int the firmware. Such a practice is common on most electronic equipment, hope you are lucky. Otherwise look for an answer on Tyan forums or Tom's Hardware
Motherboard Led codes
Is this a bios error code onthe onbaord diagnostics?
As this is a server board be careful - reset the bios to defaults is the first step in solving motherboard issues.
Remove all cards and begin testing - remove all ram chips except one and test replacing stepwise until you have isolated the issue - usually the bios error code is the last item to pass before failure.
Looks like it could be DMA controller failure but you would need the manual for the board to be sure.
Code e1 on a s2668
It is a bridge initilization error according to the manual. I would try removing the memory and just use 1 module and see what happens. If that doesn't work, try pulling other components, including the video card to see if you can isolate the problem.
I am trying to install
Hi Can you tell me the brand and model of the mainboard and I'll get you what you need, those details read on the mainboard, the brand is often between the expansion card slots, Asus, Abit, Gigabit, and similar, it can also be between the cpu and the memory. The model is around the same area, if you are not sure, post me everything you find. thanks
