20 Most Recent
ASUS A8V-VM SE (MB-A8VVMSE) Motherboard Questions & Answers
I have a A8V-VM Ultra
Go into your bios settings make sure your hard drive is set to IDE and make sure secure boot isnt on. You could just try resetting to default.
Also check your ram. Take out one then the other. This usually happens when Windows loads the files it is about to install into the ram. It takes up a lot of space and could cause faulty ram to overload.
Display driver
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or you might need to download one
if this package is not the right
http://download.cnet.com/asus-agp-v3800-series/3000-2108_4-10163292.html
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need all software windows software mac software mobile and web apps http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
I want drivers software
This would be where you need to go to download all the drivers (and their corresponding applications) for your system board. Just please make sure to select the correct operating system version.
DISPLAY DRIVER
Sir click
here to download your driver, select your OS and VGA driver provides only for XP then select VGA and start download. After your download finished double click on exe file and follow the instruction to instal your graphic driver.
No video at all, no
Hi,thanks for using fixya,
Switch off the computer and open pc cover.
First
check the ram, clean by eraser or with solvent and install again ,if
the problem same install thre ram to another computer either it damage
or not .If the problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos
jumper and hold " on off "switch for 40 seconds. Install battery again
and start pc .
Now please check the "smps" by another new or by your "smps" to another pc to confirm either it damage or not.
http://site7.way2sms.com/jsp/Main.jsp?id=6BEFB035C72C9BC7795F7E8D4A2E60B9.a403
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the capacitors, beside the processor, with the help by nearest technician.
2.Set
an identification Mark, on the bios chip, by the permanent marker
because you need to remove and install it.It could not be possible for
all mother board .
3.Remove bios chip from base , clean with solvent and install it proper again.
4.For
Intel mother mother ,install a flopy drive and switch on the power
and,follow the flopy drives "led light", either it glow or not.
If
the flopy drives led light on,download bios filre for your intel
mother board ,paste on flopy.follow the bellow link for download.
5.Now
don't switch off your motherboard at the time of updating the bios,so
please use an ups,and insert the flopy, along with bios file.Set the
cmos jumper in recovery mode( just change the normal position ),and
switch on motherboard, hope, through this proceses, should recver the
mother board.
If the problem is same, I will recoment you for new motherboard.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
I installed Windows 7 on
You can always have choice you know . Now as your ON board Sound card is not working with windows 7 you can buy a Sound card for replacement like of creative and other companies... they would be the best choice at low cost and windows 7 compatible... But before buying it please try updating your driver.
Does not boot OS. Hangs
Test all leads that attach to your hard drive including IDE,SATA and electrical extensions also from your motherboard to your hard drive or just replace them also make sure that all cd,dvd,
3.1/2floppy drives connections are secure and not faulty then uninstall programs you do not need or use then run chksdk/f then defragent your hard drive
Asus A8V-XE motherboard keeps shutting down
Hi
Kindly see if the CPU fan is working properly. This might be a system shutdown due to overheating components
Hope it helps..
Thanks for reaching Fixya.
Leave comments for further assistance.
HOW TO CONNECT FRONT SIDE USB PORTS
*********** board as option to connect the front usb ports check where the ports are available, insert the cable your front usb port will be work.
