20 Most Recent
Vieluxe 370102 (NG) All-in-One Grill / Smoker Questions & Answers
Igniters stop working. replaced once
The igniter is warrantied by the manufacturer for 3 years. And now you're on your second one. I was just wondering, have you changed the battery in the igniter button? If so, was it installed facing the same direction as the one you replaced? Was there any corrosion on the battery holder contacts? If so, a Q-Tip & WD40 does well cleaning it off. Also, the ground wire from the ignition module may be loose and is not making contact with the grill's frame. When that happens, the spark ignitors won't spark.
I hope these few things, that have been pointed out, will save you the trouble of having to replace another ignition module.
Thanks for choosing FixYa.
Rotisserie Burner does not light
The procedure for lighting the rotisserie burner is different from the other burners. This burner has a safety valve.You will need to press in and hold the burner control knob and then continue to hold it for 5 to 7 deliberate seconds after the burner is lit.But if its still not getting lit then,--------First check out this possibilities and confirm,any of this is not causing the problem:------------------
1)Make sure there is a battery in ignition .
2)Make sure the positive side of the battery is facing you when inserted .
3)Make sure that the 2 metal fingers where the spark is supposed to be closed enough to get a spark .
4)Make sure the rotisserie ignition wire is plugged into the rotisserie ignition box .
Also click this link below for more help:---
http://technoanswers.blogspot.com/2011/05/rotisserie-burner-does-not-light.html
This should help.Thanks.Helpmech.
The auto starters on the grill are no longer
Before changing any parts, check the contacts where the battery compartment is, because corrosion on the contacts will make any good battery appear dead. If this is not the problem, then the ignition module has failed either through age or moisture that has ruined it. This ignition module is a common somewhat generic part that is known to go bad.
Is "Halal" meat safe for humans?
Hi, Carole. According to the Wiki article on Halal, it is an Arabic word meaning "permissible," referring to food, objects or actions. With respect to food it is similar in intent to the Hebrew word, "Kosher." In both Islam and Judaism, for example, pork is not considered permissible. There is much more to know about Halal, but I'll defer to our Islamic neighbors to answer more fully. Short answer: entirely safe. Enjoy!
12/27/2023 4:43:31 AM •
Grilling
Answered
on Dec 27, 2023
How to take top grill off
You need to identify brand and model. Armed with that, someone may be able to assist you. Or, you can use google to search for a user manual if you include the brand and model in the search. What follows are general instructions for a lot of grills but may not fit your model:
Open the door(s) of the grill.
Look up at the bottom side of the grill.
Remove the grill screws going up into the bottom of the grill.
Tilt the grill forward at the top and release the springs from behind the grill.
Lift off the grill.
12/22/2023 4:51:21 PM •
Grilling
Answered
on Dec 22, 2023
I need Casio exilim v7 update 1.01 and 1.02
It is recommended to visit the official Casio website or contact Casio customer support for assistance with obtaining the firmware updates for your camera.
Typically, manufacturers make firmware updates available on their official websites under the support or downloads section. You can search for "Casio Exilim V7 firmware update" on a search engine to find the official Casio support page for your camera model. From there, you should be able to locate and download the firmware updates you need.
If you encounter any difficulties or are unable to find the firmware updates on the Casio website, I suggest reaching out to Casio customer support directly for further assistance. They will be able to provide you with the appropriate firmware updates and guide you through the process of updating your Casio Exilim V7 camera.
Please note that when performing firmware updates, it's essential to carefully follow the instructions provided by the manufacturer to avoid any potential issues or complications during the update process.
I hope this helps, and I wish you the best of luck in obtaining the firmware updates for your Casio Exilim V7 camera!
6/21/2023 2:43:05 AM •
Grilling
Answered
on Jun 21, 2023
Propane not getting to burners; how do i fix
James,
Try Reseting the Regulator.....
1. Turn off the gas at the propane tank.
2. Disconnect the hose from the propane tank.
3. Open the lid of your BBQ Grill.
4. Turn all the burner valves to high.
5. Wait for 2 minutes.
6. Turn off all the burner valves.
7. Connect the gas line back up to the propane tank.
8. Turn on the propane tank slowly.
9. Light the grill using the proper ignition sequence.
Best to you.
6/5/2023 6:27:06 PM •
Grilling
Answered
on Jun 05, 2023
Where near Van Nuys, CA can I buy a propane gas line with regulator to replace the one on my Grand Hall barbecue grill model 7060
Amazon, or Home Depot. They are a standard unit that fits any grill. Why are you replacing it? They don't wear out. Sometimes they will lock out and need resetting.
https://www.google.com/search?q=propane+gas+line+with+regulator
Or any of these
Bbq Store Van Nuys, Los Angeles, CA
Yelp
https://www.yelp.com > search > find_loc=Van+Nuys,...
Reviews on Bbq Store in Van Nuys, Los Angeles, CA - BBQ Store, Barbeques Galore, Fireside BBQ & Appliances, Burbank Fireplace & BBQ, Armand's Discount ...
BBQ Grills Van Nuys
Extreme Backyard Designs
https://extremebackyarddesigns.com > bbq-grills-van-...
BBQ Grills Van Nuys. We carry a huge selection of Outdoor BBQ Grills to fulfill your grilling wants & needs. At Extreme Backyard Designs we have a huge ...
The BBQ Grill Outlet ' BBQ Grills, Smokers & Outdoor Kitchens
https://bbqgrillsandislands.com
The BBQ Grill Outlet offers the best gas grills, BBQ smokers, outdoor kitchens, pizza ovens, fireplaces and more! Compare the best BBQ brands!
5/20/2023 1:11:40 AM •
Grilling
Answered
on May 20, 2023
