20 Most Recent
Ricoh Aficio Sg 3110Dn - Printer - Color - Ink-Jet Questions & Answers
Can you please help me with the error 28113 ricoh sg3110dn
Paper pinch roller is having some problem may be there is a paper jam or Cartridge try to remove all papers then remove the ink cartridge pull out the power wait for some time ,put back the paper without ink and paper
check if the error is changed if yes replace your ink if still there check for any paper jam clean it all properly and start again.
HOW TO REMOVE ERROR CODE 28212 RICOH 3110
In most cases this error is just a scam to make you install a new carriage, that you probably don't need. Without changing anything, attempt the following procedure:
Push the maintenance key.
Once you're in the greyed out menu, type #, *, OK
This will bring you to the service menu.
Select
Select "Engine Maint."
Enter code 3009002
Select Execute, press enter.
Switch it off.
Start the printer again with the cartridge door open.
Close it upon request.
At that point a 6 minutes ink reloading procedure should start by itself (if you're using original cartridges, this will cost you an eye as half of the cartridges will be drained).
After this the printer should be good as new, if no hardware issues are present.
Error code 28113
good day can you please advise me how to remove error code 28113 i got RICOH sg3110dn
regards
khan
Ricoh Aficio Sg 3110Dn erorr code sc (20200)
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
How to fix the error sc 20220
If the error you are talking about is SC202, then you have a laser problem. You will need to either replace the Polygon Mirror Motor or the complete Laser Unit if it comes as one assembly.
57000 error
hi
please my SG 3110DN printer came up with this error code : SC 57000
