20 Most Recent Samsung LE26R74BDX 26 in. HD-Ready LCD Television Questions & Answers
4answers
Samsung Remote Control not working
any samsung remote will work any samsung television. Samsung use the same code for all television's as do Sony
Samsung remotes are quite expensive you could always buy a Sky digibox remote and tune that in to work you tv that would be a cheaper option.
how to tune in the sky remote to work your samsung tv
TV,
RED + SELECT ( blinks twice)
TV,
0060
TV,
SELECT.
Job done
Hope this helps you out.
Cheers
Little Dish Fitter
9/18/2019 4:25:36 AM • Samsung... • Answered on Sep 18, 2019
IR receiver on TV
Might be. Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean. https://electronicshelponline.blogspot.com/ https://homenol.blogspot.com/ https://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://youtu.be/wUpnETSm6_k https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]/
3/4/2018 4:18:58 AM • Samsung... • Answered on Mar 04, 2018
Samsung television cannot change program up or down.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://youtu.be/wUpnETSm6_k https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
5/11/2017 8:16:03 AM • Samsung... • Answered on May 11, 2017
2answers
How do I turn on
Button at bottom center of front is power button.
Other buttons on the right hand side.
http://downloadcenter.samsung.com/content/EM/200605/20060509211535718/EN/3_sub.htm
3/18/2015 10:22:03 PM • Samsung... • Answered on Mar 18, 2015
2answers
Restore TV guide to television
Refer its user manual for details. If you haven't it with you now, download it from http://www.retrevo.com/ http://electronicshelponline.blogspot.com/
3/1/2015 3:55:55 PM • Samsung... • Answered on Mar 01, 2015
Samsung flickering fix
try this option reset settings to factory default reconnect lcd cable from mainboard to lcd panel
9/8/2014 9:11:42 AM • Samsung... • Answered on Sep 08, 2014
Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
5/12/2014 12:56:00 PM • Samsung... • Answered on May 12, 2014
Power turns on and off by itself
Your power cable might be a little loose, happens with my TV too.Try to push it in a bit, just a bit.If there is the same problem again, try buying new power cable, and if that does not help, your TV will break soon.
9/10/2013 7:54:34 PM • Samsung... • Answered on Sep 10, 2013
Samsung le26r74bd won't retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
4/22/2013 6:44:09 PM • Samsung... • Answered on Apr 22, 2013
Remote is dead
Most remotes can be tested and if bad fixed, look if test shows not sending for battery connections, something has been spilled on it or if suspect it was dropped the actual led/s inside that send the signal have come loose from the board where they are soldered in.
12/23/2012 8:36:15 PM • Samsung... • Answered on Dec 23, 2012
LE26R74BD power board
No, not power board actually..You possibly have bad inverter board (this board is responsible for creating back-light) if this fails your TV black screen,
12/13/2012 10:07:52 AM • Samsung... • Answered on Dec 13, 2012
My lg lcd fhd tv remote stopped wrkin, put new batteries still nothing
try taking it to a shop they will get you a new en ( where they fix tech stuff not morrisons or asda)
10/14/2012 4:22:38 PM • Samsung... • Answered on Oct 14, 2012
0answers
Samsung 26 R74BDX All that is
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck in solving the problem.
8/5/2011 12:35:33 PM • Samsung... • Answered on Aug 05, 2011
I need to reset to
1. Press the d.menu button to display the DTV menu. 2. Press the up or down button to select "System", then press the enter button. 3. Press the up or down button to select "Reset", then press the enter button. 4. The "Enter PIN" screen will appear. 5. Enter your current 4-digit PIN code by using the numeric buttons (0~9). 6. Press the exit button to exit.
Manual - http://downloadcenter.samsung.com/content/UM/200603/20060325173246984_BN68-01007A-00Eng-0302.pdf
5/6/2011 8:40:04 PM • Samsung... • Answered on May 06, 2011
Cant retune to pick up dvb samsung le 26r74bd
Hi return the TV with out the aerial connected and wait until it finishes then plug the aerial back in and try again. Let me know how you get on.
11/1/2010 11:37:10 AM • Samsung... • Answered on Nov 01, 2010
Samsung LE26R74BDX 26 in. HD-Ready LCD Television Logo
68 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
remote dead
  • Televison & Video
