20 Most Recent Hannspree XV32 32 in. LCD Television Questions & Answers
0answers
I have 32" hand spree TV hooked up to satellite box with a cable connected to the hdmi 1 port. Problem locking to hmdi1 port
Check in the menu of the tv do there is any option to select the input source. If so the select there its to hdmi 1. after that turn off the tv and ON again and check do it go back to TV mode. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
6/25/2016 9:45:04 AM • Hannspree XV32... • Answered on Jun 25, 2016
3answers
Need assistance on hannspree 32p
I've had exactly the same problem and it seems to be happening across a whole range of 2 year old LCD TVs World wide. Replacing the Inverter seems to be the only solution (sometimes but not 100% effective). I'm trying to track down if you can get an Inverter for a Hannspree at all and if it's going to be cost effective
1/17/2016 9:36:15 AM • Hannspree XV32... • Answered on Jan 17, 2016
How do you connect a potable dvd player?
If the dvd player has a hdmi contact you should use this. In the tv's menu you should be able to define the hdmi contact in use. The same goes for a scart contact. However, if the dvd player has a cart contact only and the tv has no scart contact, I am afraid that you cannot use that player. Anyway, you should consult the manual, that you have been adviced to download. Good luck.
8/7/2014 7:55:53 AM • Hannspree XV32... • Answered on Aug 07, 2014
2answers
WHERE DO I FIND A MANUAL FOR LCD TV HSG 1210?
Contact the manufacturer they will be glad to provide one
5/9/2014 12:52:00 PM • Hannspree XV32... • Answered on May 09, 2014
Sky remote code?
If you wish to get more details; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
3/26/2014 11:05:40 AM • Hannspree XV32... • Answered on Mar 26, 2014
No remote or code. only get one channel with manual turn on.
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand. To select a proper universal remote control, you should know about the number of digits to its set-up codes.There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices.After confirming this, check the sites linked here.Both the sites have set-up code list and set-up procedure to many popular brand remote controls.Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability?Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual.Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier. http://electrohelponline.blogspot.com/
2/13/2014 6:06:56 PM • Hannspree XV32... • Answered on Feb 13, 2014
Hannspree xv remote code
Try ViewSonic LCD codes, code 1330 worked for me.
12/6/2013 2:08:47 PM • Hannspree XV32... • Answered on Dec 06, 2013
0answers
Handspree Closed Caption
Download the user manual to this set. It will have all details you want.
6/8/2012 4:20:45 AM • Hannspree XV32... • Answered on Jun 08, 2012
Black screen- fixable?
probably a faulty internal PSU, changing the capacitors on the on-board PCB should fix it but hard to tell without opening it up and testing.
4/26/2012 7:23:15 PM • Hannspree XV32... • Answered on Apr 26, 2012
Jt01-32e2-000g no power
see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.3_29_2012_12_34_07_pm.jpg
3/29/2012 12:34:16 PM • Hannspree XV32... • Answered on Mar 29, 2012
Want to connect compaq 610 to tv
If both have an HDMI connector you should be able to buy an HDMI cable and be in business. If you need one try this site with cheap prices and great service: www.monoprice.com
2/8/2012 9:36:57 AM • Hannspree XV32... • Answered on Feb 08, 2012
After 3 to 4 hours the picture goes bad on screen.
How old is the tv
9/26/2011 2:59:55 PM • Hannspree XV32... • Answered on Sep 26, 2011
Hannspree XV32 32 in. LCD Television Logo
65 questions posted
Top Hannspree Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hannspree Televison & Video
Most Popular Question
32 hand spree tv hooked up satellite
  • Televison & Video
