20 Most Recent Brother DCP-J140w Wireless Compact Inkjet All-in-One Dcpj140w Questions & Answers
2answers
ERROR 48 ON BROTHER DCP 140W
Print head is damaged. Needs repair or replacement.
7/31/2021 10:58:32 AM • Brother... • Answered on Jul 31, 2021
My brother DCP-J140W printer ink box full .. please help how to fix it.
The Brother manual says that you are required to replace the ink absorber box at a Brother Service Center. This is not an item covered by warranty. http://www.manualslib.com/manual/437931/Brother-Dcp-J140w.html?page=44
7/30/2021 12:35:11 PM • Brother... • Answered on Jul 30, 2021
I have a problem of my printer, it shown in the lcd "Init unable 4F" for brother DCP-J140W printer, what it means?
Sorry... Print head damaged. There is an very low possibility to erase the error without buying new print head, but it's unprofitable
3/16/2021 4:23:00 AM • Brother... • Answered on Mar 16, 2021
3answers
My printer show error init unable 4f
Probably print head or the print head PCB is faulty.
3/16/2021 4:08:46 AM • Brother... • Answered on Mar 16, 2021
Ink box near full
heres the solution for ink box near full 1 power on the printer 2.press menu, mono, menu 3 press arrow up or arrow down look number 8 then press ok 4.press arrow up or arrow down look number 0 then press ok 5.press arrow up or arrow down PURGE Counter then press 2783 6.press 99 to exit maintenance mode or unplug the machine 7.turn back on the printer
3/16/2021 4:03:59 AM • Brother... • Answered on Mar 16, 2021
How can I solve the problem machine error 48 in brother J140w ?
Clean matance box ?? also matance box small switches
4/13/2019 11:45:42 AM • Brother... • Answered on Apr 13, 2019
I have a Brother dcp-j140w printer its black cartridge not Detecting by the printer . What I do now ?
First release ink cover door after that install Catradge slowly if problem is still clean Catradge sensor but first check ur ink cover open close is working or not
4/13/2019 11:40:30 AM • Brother... • Answered on Apr 13, 2019
My brother DCP-J140W printer ink box full .. please help how to fix it. Ty
Unplug the power card pressed menu button and then plug ?? in power cord till display showing matance mode.. After that release menu button use up and down key use up 8 press ok then also use up key press 0 and then use mono button and got purge count use up and down keys press 4 ok 8 ok 2 ok 3 ok purge count 0000 then off and on peinter and enjoy
4/13/2019 11:37:15 AM • Brother... • Answered on Apr 13, 2019
Unable to print by brother LC985 DCP-J140W (Wifi) although the colors are ok and the printer are installed, i did the test printer but the squares are not complete, plz tell me what is the problem??
The print head needs to be cleaned. Use the cleaning mode in the ink menu. You may have to do this several times to get all the squares complete.
2/9/2017 6:23:36 AM • Brother... • Answered on Feb 09, 2017
Erro cod 46
Can't install Creative Cloud Setup - error code 46 Running Windows 7 Ultimate 64, service pack 1 Getting this message on install: 'Installer was unable to access a critical file/directory. Please try installing again. (error code: 46)' In case it was a privileges issue:
  • Tried as main user which already has admin privileges
  • Tried creating a new admin user and installing through that
  • Tried activating the disabled default administrator user and installing
Also tried with antivirus/firewall disabled, and tried running Adobe Creative Cloud Cleaner Tool then running the installer again. Same error every time - any ideas on how to get this installed? Any help is much appreciated, thanks in advance Correct Answerby Tony Murphy on Apr 27, 2014 3:46 PMFinally figured it out, so here's the solution in case anyone else hits this problem - in my case it was Comodo internet security. Not sure if it was the anti-virus, HIPS, auto-sandbox, or the firewall, but I basically disabled *all* of them for a couple of minutes while I ran the installer, and everything worked fine. Switched back on and the installed application is working without any problems at all. Note that Comodo has to still be running and each option actually disabled, rather than just exiting Comodo in the systray (the protection stays on if you do that, it must be still running as a service). Hope this is of some use and saves some time/hassle for anyone else having trouble with the installer.For more information visit us:http://printertechnicalhelp.com/
9/24/2016 12:16:54 PM • Brother... • Answered on Sep 24, 2016
My scanner is not scanning the full document
please call on toll free 1-877 213 6551 for support.
2/18/2016 5:56:29 PM • Brother... • Answered on Feb 18, 2016
How to repair inboxfull
More info please
7/3/2015 12:36:46 AM • Brother... • Answered on Jul 03, 2015
How clean inkbox full
You have to replace it
5/20/2015 1:11:03 PM • Brother... • Answered on May 20, 2015
2answers
My brother DCP-J140W won't scan. It keeps saying check connection but it is printing okay. Please help!
How is the all-in-one connected to your computer? The problem usually means that you do not have bi-directional communication between the printer and the computer. If it is connected to your wireless network, did you ensure that the firewall allows the communication? (Some firewalls will automatically add the correct ports to the allowed list during the install of the full software.) For other firewall software or the less-complete install of the software drivers, you need to make sure that the port, 54925 , are allowed to access your computer for inbound and outbound network data. If adding that port is insufficient to allow scans to have bi-directional communication with the printer, also add port 137 (inbound and outbound). Since this step depends on your firewall, please add a comment with the firewall software on your computer. This is in the note in the Scanning section of the Brother Software User's manual for the DCP-J140W on page 35. This manual is available here: http://download.brother.com/welcome/doc002923/dcp140w_use_soft.pdf . An example of setting the Firewall rules for the Windows Firewall is shown starting on page 85 of the manual. If your computer is connected to the printer via a USB cable, try a different (possibly shorter 6' or less) USB cable or a different port. If you have the printer connected to a USB hub, skip the hub and directly connect to the computer. Check if other devices work at the USB ports. Sometimes ports do fail; either they can't maintain the needed voltage or they don't keep the cable and pins properly aligned. I hope this helps. Cindy Wells (I have seen the communication issues with stand-alone scanners as well. I saved a perfectly good scanner from the trash when the user failed to check if the scanner worked with other ports.)
4/2/2015 5:10:01 AM • Brother... • Answered on Apr 02, 2015
2answers
How to trouble shoot Machine Error 70 for DCP-J140W Printer.PLease help me.
Since I am working in the Techical Support department at Brother I can give you some little advice: Machine Error 70 is a hardware fault of the machine, after the Service Manual it means: "Cannot detect the ON/OFF state of cap lift cam Switch" After the instruction in the service manual the service technician would have to change the whole maintenance unit of the machine. You can try to clean the index stripe as described in faq00002918_004, but I doubt that it will solve the problem. It looks as if you have to send in the machine for repair if it is still under warranty or replace it with another brother. Best regards!
1/27/2015 1:20:58 PM • Brother... • Answered on Jan 27, 2015
I have a brother J140 W i followed your instructions to clear purge full ink box and it worked,I thought great,But now when i print the black ink goes into the yellow when I do a test I have 2 black i
Did you actually change any parts or just reset a warning? If you were getting a full error, chances are the purge system was full and needs to be changed. Likely what the problem you are having is that ink from the purge system is backing up and polluting your print heads.
1/4/2015 6:47:08 PM • Brother... • Answered on Jan 04, 2015
How can far problem print unable 50
Try one or more of these options: Replace the maintenance unit,Replace the engine unit,Replace the power supply PCB,Replace the main PCB.
12/27/2014 11:34:21 PM • Brother... • Answered on Dec 27, 2014
Black Ink cannot detect
Try a new black ink or replace the ink assembly
12/9/2014 11:40:28 AM • Brother... • Answered on Dec 09, 2014
Printer unable 70 what do i do to fix this problem
maintenance unit faulty
12/9/2014 11:33:38 AM • Brother... • Answered on Dec 09, 2014
Brother DCP-J140w Wireless Compact Inkjet All-in-One Dcpj140w Logo
29 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
DCP Brother
  • DCP Brother
Most Popular Question
trouble shoot machine error 70 dcp j140w
  • Office Equipment & Supplies
