20 Most Recent TruTech PLV16260 Television Questions & Answers
What do you mean by "mechanical way"..you would need to test some voltages to find where the issue is at
TruTech PLV16260... | Answered on Dec 14, 2017
wrong site fixya doesnt have products
TruTech PLV16260... | Answered on Jul 05, 2017
Surely; you should have. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
TruTech PLV16260... | Answered on Mar 24, 2014
Did you get this fixed?Please let me know.Thank You very much!
Tyler
TruTech PLV16260... | Answered on Mar 23, 2014
You will most likely have to have the capacitors in the supply board replaced....
TruTech PLV16260... | Answered on Nov 29, 2011
Did you get this fixed?If you have any questions,please let me know.Thank You very much!
Tyler
TruTech PLV16260... | Answered on Sep 17, 2011
Tyler
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
TruTech PLV16260... | Answered on Sep 06, 2011
Are you still having problems with this?Please let me know.Thank You very much!
Tyler
TruTech PLV16260... | Answered on Nov 27, 2010
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
TruTech PLV16260... | Answered on Nov 03, 2010
Turn your TV on and use the setup buttons on the remote control. In time, the TV will be switched off by the remote controller. At that point, save your remote control settings and it should then work most if not all functions.
TruTech PLV16260... | Answered on Oct 17, 2010
Did you get this fixed yet?Please let me know.Thank You very much!
Tyler
TruTech PLV16260... | Answered on Oct 15, 2010
Does it light up at all when you first turn it on?I would have to say the inverter(The board that lights up the screen) is bad.If you open the back of the TV,it is the board to the left under the metal cage with the row of pink,and white wires coming from it.Thank You very much!
Tyler
TruTech PLV16260... | Answered on Oct 10, 2010
Please let me know if you got this fixed.Thank You very much!
Tyler
TruTech PLV16260... | Answered on Sep 03, 2010
Tyler
TruTech PLV16260... | Answered on Aug 30, 2010
FAULTY POWER SUPPLY CAPACITORS
AVERAGE REPAIR COST £60 TO £80
TruTech PLV16260... | Answered on Aug 25, 2010
Tyler
TruTech PLV16260... | Answered on Aug 12, 2010
TruTech PLV16260 Television Logo
57 questions posted
Top TruTech Televison & Video Experts
Eric Rotmil
Eric Rotmil
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • TruTech Televison & Video
Most Popular Question
remote in french
  • Televison & Video
