20 Most Recent
Toshiba Qosmio G10-133 Notebook Questions & Answers
Cannot get audio feedback when
on the taskbar close to the date and time there is a speaker icon
click on speaker icon
click on mixer
click on explorer volume controll
Lost bios password thoshiba qoasmio
To reset the BIOS read the information from this
link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
My Toshiba Quasimo has red
Plug the computer into an external monitor. If the picture is normal the screen on the laptop needs replacing. If there are lines on the external monitor then its the motherboard.
Welcome to Toshiba
I have toshiba Qosmio G10 I lost all My Bios
cant lose the bios its built into the machine itself
you can change the bios settings but not lose it
more like like a power supply, ram ,motherboard or hard drive issue
If you need more help please ask but I will need more details of your problem,
Cheers Misterdj
Pleas i av a problem with my toshiba qosmio g10 i
These are steps to setup the Audio and to restore the Audio: drivers. Part (1) Click the "Start" button. Go to, and click in the (right, pane) Control Panel. Scroll to find, "Ease of Access (or) Speech Recognition Options. "Click on," Replace sound with visual cue." In the See also (Category) click on, Audio Devices and Sound Themes. Click, Playback, next, click on the Active "Speakers" Click 'Configure' to "Audio channels" The (Speaker Setup) "wizard", appear! Select (Test) click, Next. Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. The (Advanced), not recommended! In, the Controller Information (block), click on, Properties to"update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: “Click, "OK", Save and "Apply" to all changes before exiting.” To finish, restart the Computer!" “ Did this solution help?”
No Display
I too have the same problem any ideas from anyone would help
Lines on the Laptop screen
LOL, well you know where to come if you have issues with the laptop! And best of Irish luck with the new book!
Slonshe! (Sorry, cant spell in Irish..)
IrishDruid
Lines on the Laptop
You are most welcome. Just visited your website. Pleasure to meet an Author!
Wireless connectivity problems (Qosmio G10 and Satellite A110)
Ok solution to this problem is simple! First determine if there are Wireless household phones around! 2.4 GHZ. These phones use the same exact frequency your Router does, and wireless cards. Channels I believe 8,6,and 11. Your phone hops between these when a call comes through and the channel is not clear. So hence the problem. Now another problem would be that the your firewall is not allowing your PCs to connect to the wireless network. So you may need to let down your firewall to reestablish connection. The other solution would be to erase all of the web access points you have visited from your network connections settings tool properties. Sometimes when this gets filled you card will not be able to scan a new network. The other solution would be to plug in the information manually into your Network adapter. These are all simple fixes! If this does not help drop me a line. I have plenty more answers! I cannot put them all down considering I only know based on the limited information!
When laptop says no bootable device
It means that you do not have a hard drive that can be booted to start the OS, or that your had drive is defective, or the boot sector of the hard drive is missing or corrupted.
Wireless capability turned on
You just got wireless turned on ?
Does this mean you just added a wireless router to your existing wired network ?
You may need to turn off the DCHP server in the wireless Router and give it a unique ip address eg if wired router is 192.168.0.1 then make wireless router 192.168.0.2 with gateway ip set as 192.168.0.1 then make wired dhcp router not lease out 192.168.0.1 - 192.168.0.20 make subnet mask the same also for each router.
Beep codes
Did you solve the problem? I have the same here, in Brazil.
