20 Most Recent
Toshiba Tecra 9000 Notebook Questions & Answers
Well I was trying to load xp pro and it froze and
Hard drive might have failed or there could be other faults. Try removing the hard drive and switching on. Switch off and reinstall the drive and switch on again.
If this restores the drive to the list then all should be well, if not try a new or different drive.
My tecra 9000 will be in use for awhile and then a
These are possible techniques on how to resolve this particular behavior. Try these subsequent suggestions.
Memory Check - Dislodge extra memory out of the motherboard; run only the module needed to start the system. Reboot the system to see of the error still exist. If the error message does not materialize, the problem is one of the memory cards you have removed from the motherboard. This procedure may take several times since you have to try every RAM to determine what causes the problem. If you have detected that a memory module is defective, replace it.
Adapter Check ?€" Remove installed adapter leaving only the necessary adapter generally a single video adapter and the subsystem controller. Restart the computer to see if the problem sill occurs. Try to reinstall every adapter and reboot the system separately, reboot after every adapter. If the error does not appear after reinstalling each of the adapters, the card may only require to be reseated. Monitor the system to guarantee that the error will not reappear.
How can i get wifi and lan to connect?
Make sure your wifi button/switch is turned on. It should automatically find and connect. You may have to put in the security key. Also you can go to Start-> My network places, on left set up wireless network. It will walk you thru it.
I left my laptop on
If your laptop was sitting on a bed, soft chair or something similar it probably just got too hot. Let it sit for a few hours before attempting to power it back on.
I search for a driver
Drivers are dependent on the version of Windows installed. You can download from Toshiba support page but they may only work on XP or older. If you have installed a new OS, try installing XP drivers or search Windows update.
Click here to go to Toshiba driver download page. Drivers are for Tecra 9000.
How do you locate the
The hard drive is located on the left side of the unit between the video out port and the select bay(cd-dvd drive). You will see a small cover that you will need to remove to gain acces to the drive.
Make sure that you have the unit unplugged from the power supply and that you have removed the battery before opening this cover.
I hope this helps.
I put in cd and it does not recognize it-i have a
The autoplay feature on some refurbished (and sometimes new) computers is at best unpredictable.
To find out if your disk is recognized, go to MY computer: It will display the drives and if they contain anything, it will show there. In the event the disk is not Labeled, double click on the CD rom icon, if the contents for the drive come up, your drive is ok, and the disk is too.
If the contents of the disk do not show up, but the drive is displayed, recycle the drive mechanism.
(open/close)
If that still does not do the trick, reboot your computer, and try again.
As a last resort, an external drive via a USB connection will give you the drive contents.
Good luck and don't forget to vote.
When i search for wirless availability there is
If you have wireless at your location, then there is a good possibility that the wireless adapter is turned off. Check your manual on how to turn it on or look at the keyboard and see if there is an on/off function for the wireless. Typically when it is on, you'll have a flashing light indicating it is sending/receiving.
MOD. PT900E-03SFK-IT
The sound board in your Tecra 9000 is probably okay - the connector located on the I/O board is most likely at fault here (it's not making full contact with the I/O board and therefore, your sound board is functionally not connected).
Solution? Either resolder the connector on the I/O board, or replace it with a good one.
Set hard drive password toshiba techra 9100
hi
1) it is very risky to unlock it on your own .it involves shorting of pins on the motherboard (remove the Cmos battery and put it after 1min)
clear the password
OR
2) using software www.hddunlock.com to to unlock the harddisk
OR
3) just got to a Toshiba authorized service center and get it Fixed
my friend was charged Rs.1000
Tecra 9000 problems on keyboard
reinstal windows xp and during instal select keep old programs do not format it then you have acces to al installed programs befor
also save you emails and adressbook (wab) file they wil be overwritten
if problems stay try to connect extern keyboard on usb port with a cable you can buy on computer store
