20 Most Recent
Toshiba Satellite P105-S9312 Notebook Questions & Answers
My toshiba laptop is typing wrong characters but
Sounds like the laptop keyboard went bad and thats why its typing wrong characters. Best way to verify this is to use a USB keyboard on the laptop, if the USB keyboard is typing the correct keys then you know the laptop keyboard is bad. If the USB keyboard is typing the wrong keys as well then you know its a setting in windows that is causing the keys to type wrong characters.
8/20/2014 2:29:56 AM •
Toshiba...
Answered
on Aug 20, 2014
I have a toshiba P105-9312
probably the in build graphic chip is defecting.. try to locate it and apply little preasure with your fingers while starting the mobo. if success - then you can try to rework/resolder it, but special tools are needed (hot air soldering iron, or infrared rework station..)
9/18/2011 4:28:35 PM •
Toshiba...
Answered
on Sep 18, 2011
I can not type at@
This usually happens when the setting for the region are wrong...
go to control panel, open Regional and language options and make sure that all the settings are set to English(United States)
If you find that this is information was helpfulto you, please rate me and leave a comment as this will encourage me to do morefree work for you and others. And please let me know if there's anything else Icould help you with. Without any inputswe cannot proceed assisting free of charge... Thank you for using FIXYA!
Best regards,
Junior
9/15/2011 11:55:56 PM •
Toshiba...
Answered
on Sep 15, 2011
I CANNOT TYPE @ IN MY SONY LAPTOP I ALSO I CANNOT
Hi Rabin,
hope you r doing good,
in laptops there are shortcut for num lock button
Hold the Fn (Function key) and scroll lock this will act as a numlock key
to type @ press shift +2
I hope i have answered your question
Thanks and Regards,
MechIntoSoft
3/3/2010 11:52:15 AM •
Toshiba...
Answered
on Mar 03, 2010
I can't type @, # and ~ on my laptop
You may have your NumLock enabled. That will make you type whatever blue characters are on the keys instead. Press your NumLock (sometimes Num Lk) button and see if that helps.
If that's not the case then you probably have the wrong keyboard profile enabled in Control Panel. (Thinks you are using a foreign keyboard layout of some sort.) If the above solution doesn't wok, open up the Regional and Language Options from Control Panel, select the Languages tab, and press the Details button under the Text services and input languages section. Make sure everything in there applies to you.
5/13/2008 1:51:17 AM •
Toshiba...
Answered
on May 13, 2008
I cant type @, # and ~
Everytime I try to type @ (shift - 2), " comes out instead of @. The same problem for typing ~ (shift - 1) and # (shift 3), but other comes out. Any solution?
My Toshiba Laptop is P105 Professional Premium Series.
Thanks in advance.
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
How can a fix error code oxcoooooof
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
3/19/2020 10:52:50 AM •
Toshiba...
Answered
on Mar 19, 2020
How to play a DVD on Toshiba Satellite Pro C850
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
3/11/2020 8:58:46 AM •
Toshiba...
Answered
on Mar 11, 2020
My computer does not connect to wifi and only show
Hello,Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it. You can use
RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer. Davidhttp://goo.gl/CxsY9u
9/25/2019 4:52:00 PM •
Toshiba...
Answered
on Sep 25, 2019
