20 Most Recent
HP Compaq Presario V5207NR Notebook Questions & Answers
Compaq Presario V5207NR (EZ430UAABA) PC Notebook: I have a compaq presario v5207nr and have recently...
old compaq, with full service tag data wow./! 13 years old now.
XP right? 2001 to 2007, your PC did not have vista. new.
XP is dead, did you know that?
then you fail to tell what OS is running,
guess what that matters, (we know what it was new but....)
if it's XP and or vista is does, XP is dead now for 4 years.+
and worse IE is even more dead, and now banned on many web sites and is an expanding *****.
did you go to MX owned skype home page and read the minimum requirement there, first?
there are 3 issues here.
- XP is dead.
- your XP microphone be died
- your XP webcam is dead, all very normal now.
here is what skype said, believe it.
https://support.skype.com/en/faq/FA10328/what-are-the-system-requirements-for-skype
as you can see new skype is dead for XP
XP is a virus magnet as is its unsupported IE versions, (all)
note the tight restrictions on w10, wow.
2/21/2018 3:02:40 PM •
HP Compaq...
Answered
on Feb 21, 2018
I cannot open the mms in my phone
That has to be a configuration problem. you need to request for configuration settings from your service provider. when the settings is sent and you install it, you start browsing again. thanks
8/13/2011 8:28:05 AM •
HP Compaq...
Answered
on Aug 13, 2011
GRAPHIC PROBLEM & VIDEO IS
If you have reinstalled Windows then you need to install the Presario device drivers.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
6/29/2011 10:43:04 AM •
HP Compaq...
Answered
on Jun 29, 2011
Went to hibernaye on it's by itself will not come
Some laptops/Notebooks automatically go to sleep/hibernate when their power level gets too low. Try plugging in an adapter then pressing the power button again while it's plugged in.
Rate if this helps
1/15/2011 5:55:48 PM •
HP Compaq...
Answered
on Jan 15, 2011
I want to have my
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies and
Driver
downloads
(if applicable) as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
12/31/2010 9:40:32 PM •
HP Compaq...
Answered
on Dec 31, 2010
Streaming Video starts and stops
This is a very common problem and the possible solutions are many, but the most common problem is that the computer is a bit slow for such things as watching videos on the Internet. You could check your performance tab under Task Manager to see how your computer CPU speed is affected while starting videos. Press Ctrl-Alt-Del keys to bring up the task manager, then go to the performance tab and watch for the percentage CPU usage while under load. Also make sure that your Internet speed is fast enough. Also, sometimes programs such as anti-virus programs will activate when you do something new like start a new program and it will cause delays in the software. The solution for this would be to try another anti-virus software or disable it temporarily just to see if that is the problem.
9/12/2009 7:20:03 PM •
HP Compaq...
Answered
on Sep 12, 2009
Compac presario CQ62
Hello
Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine.
usually F11 or F10.
others has DVD, check and see what you have of these two.
in the first one, you recover from a disk partition the whole OS.
Bios update fore presario 8000
Its all about go to HP page, and bios updates, the instructions are there too!
but be aware you have to be more specific on model, and BIOS dates.
Compaq presario sr5350f pc and i keep gtting windows is shutting down everytime i click the help button
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luckG
Hp 6830s
If the fan making a smooth spin, but the noise is too loud, then it means the fan is trying to dissipate the heat. Probably the air inlet and or the air outlet (also the fan itself) is dirty (or clogged) and you need to clean it up using a canned air.
You may need to open the case/body if the dust become a dust ball (and you need a tweezer and qtip to pickup the dust ball and clean up the fan blades).
