20 Most Recent
Toshiba Tecra A8-EZ8313 Notebook Questions & Answers
Trouble install soundcard di toshiba tecra
You need to goto
the manufacturers website, find their support section and there should be a
list of drivers for your specific machine. Installing these should resolve your
problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Hi, I have a toshiba
The only drivers that will work ard on the Toshiba web site and if there isn't one, theoretically the machine is not Win7 compliant.
If you speak to the technical department there, they are extremely helpful.
Remove password toshiba tecra a8
open the back of the computer , remove plastic cover , there you will find a battery, Lithium (size of a quarter), discoonect the connection for 30 seconds , place it back
if no connection present, remove the battery (carefully) and place it back after 30 seconds
It's a Toshiba bug, the know about it. They'll repair it for free at an authorized repair center.
You can find one here:
http://welcome.hp.com/country/us/en/support.html
Bios Password
Deer GeekMan,
thanks for your solution. it seems usfule but my notebook didn't has printer port(paralel port).
it just have usb,and s400 port(smale port for usb printer)
BIOS PASSWORD
This is a Toshiba bug.
Find an authorised repair center here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/gaspLocator.jsp?subs=tais
They'll fix it for free. Should take them only a few seconds so try to convince them to repair it while you wait to save yourself time.
I need to upgrade my DVD drive in my Toshiba Tecra A8 EZ 8313
you have to remove several parts that cover the dvd drive enclosure
the keyboard is one and the power and light display at the top of the keyboard is another section that you have to remove they pop out and are not hard to remove but be careful as they have little clips that hold them in once they are out you will be able to see what screws you need to remove.
Toshiba Tecra R85. CMOS battery location on it please?
is that a typo OP< R850 is it?
use you tube, key word dismantle.
or replace motherboard.
see coin cell in the process.
found it for you and is special battery rechargable it is, no CR2032 sorry
R850 found it by pretending to buy the whole mobo.
see the red x, it is bundle of batteries
like this
using the wrong battery it will explode, the users guide said that . and will.
Built in hdd error
remove the hdd and attach to desktop .
right click in my computer and run check disk in tools section in drive properties
Toshiba tecra s3 supervisor password reset
1. try with clear cmos and remove AC adapter and main battery.
2. also pls try to remove the code with password re set web site or password remove tool in hiran boot cd
Toshiba tecra no image
need more information to determine the fault. but you can remove the battery and pls plug ac adapter and also re seat the RAM. power on and test
My phone is not turning on
I have had this on an iphone 5. Apple sold me a new phone as it was not worth repairing and it was out of the 12 month warranty. Its possible to order a new part and do it yourself but unless you are totally confident and have the skills to open up your phone and reassemble it then its just not worth it.
