20 Most Recent Gateway ML3706 Notebook Questions & Answers
My pc boots, the the screen is completely black.
If you can see the bios screen at the boot . After that your screen is black.
The OS might be corrupted I suggest you to reinstall the OS by using the re-installation Disc.
If you are getting any beep sound then the error codes of one long beep & 2 short beep Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
If you don't see the bios screen & beeps, there might be problem with the screen or the VGA chip in the motherboard.
If so I suggest you to contact the service center near by.
I am sure this will be helpful for you.
Rate my solution
Regards
7/4/2014 11:09:01 AM • Gateway ML3706... • Answered on Jul 04, 2014
Gateway Ml3706 wont boot up BOOTMRG missing . runs on vista
Are you using Windows Vista? You can fix this problem bt using your installation dvd. After the first couple of scrrens, you will get an option to REPAIR the installation. You should get a functioning system after that.
3/3/2013 5:47:02 PM • Gateway ML3706... • Answered on Mar 03, 2013
2answers
My gateway laptop will not turn on when you push power button.
If you power it on and get the light it means either two things:
1. It needs a minimal charge on the battery to power. ( havent seen this since the old Compaq/Apple stuff ) or
2. The motherboard is fried. ( Just diagnosed a HPDV6000r special edition with this beautiful computer, dead motherboard ).
What is the warranty like:
NOTE TO ALL STUDENTS: Buy New laptops in November, so the warranty comes up in October, after you know you need more computer or repairs!
12/2/2012 6:55:51 AM • Gateway ML3706... • Answered on Dec 02, 2012
My gateway Ml3706 laptop shuts off after 5-10 min
Random reboots are usually an overheating problem. First step is to look into the vents and see if they are clear of dust, fuzz, animal hair etc.
If they are clear you will need to access the fan/heatsink. The heatsink can accumulate dust depending on the design. If the fan sounds "abnormally loud" it could have bad bearings from dust and dirt and may need to be replaced.
Most laptops come with some way to monitor the temp, usually in the bios. Occasionally they come with a utility. You can use that to check the heat levels.
6/28/2011 6:10:53 PM • Gateway ML3706... • Answered on Jun 28, 2011
On my gateway laptop every time i seem to watch a
There is a problem with your driver. Try downloading it and reinstalling it. If that doesnt help then you most likely have a problem with your video processor.
3/23/2011 4:53:05 AM • Gateway ML3706... • Answered on Mar 23, 2011
My computer locks up about every 10 minutes what
Probably needs more RAM. How much is in it? The locking up could represent a bad memory sector in your current RAM (the computer locking up every time it hits that sector(s)) among other things. You can grab a linux live CD and do the memory test to be sure...it takes a long time tho.
You can speed up the startups by going to Start > Run > MSconfig and tweaking the tab that has the programs that start when windows starts and tweaking the services that start up...just be sure of what you are turning off
10/13/2010 10:33:15 PM • Gateway ML3706... • Answered on Oct 13, 2010
SATA to PATA adapter or...
I don't think you will find an adapter than will fit into a laptop - they isn't any space.
You will need to buy a SATA.
You can by and enclosure for PATA hard drive and make an external drive to back up your stuff (if you can't return it).
2/27/2010 7:41:55 PM • Gateway ML3706... • Answered on Feb 27, 2010
Gateway ML3706 no recognized hp deskjet d4360
Try and go to printer and fax setup the add printer maunally it will ask that do you have driver for your pinter then click yes.........
10/24/2009 5:17:16 PM • Gateway ML3706... • Answered on Oct 24, 2009
I need to know how to get the bottom off my laptop
the bottom doesn't come off......you have to remove the cover on the screen hinge and remove the keyboard and monitor to isolate the "bottom" of the unit. After you have removed the panel on the hinge, you can unscrew the keyboard and detach the screen. At this point the bottom can be removed by taking off the main boards and other connected components.
Good Luck and please rate this post
10/4/2009 5:17:12 AM • Gateway ML3706... • Answered on Oct 04, 2009
2answers
How can I set my computer to a factory reset?
most new computers have all you need /ok turn on goto windows goto shutdown /restart as the computer starts again from blank screen hold f12 down then follow on screen instructions / if not repeat and try f10 if not repeat then f11 ---ok
8/26/2009 9:53:35 PM • Gateway ML3706... • Answered on Aug 26, 2009
0answers
3answers
Wont bootup at all keeps saying BOOTMRG is missing
  1. Boot off the Windows Vista DVD
  2. Click Next at the first prompt select the language and click next.
  3. Select the link in the lower left-hand side for "Repair your computer"
  4. The installation process will attempt to find your Vista installation directory.( If there's more than one in the list, select the correct one and then use the Next button again.)
  5. Click the first link for "Startup Repair" (Or the last link "command prompt" if you want to use the alternative method as described below)
  6. The installation process will repair the system, and then prompt for you to reboot.
Alternatively you can choose the Command Prompt option instead to fix the boot only:
  1. Follow step 1-4 above
  2. on step 5 choose The last link "Command prompt"
  3. type bootrec /fixboot and hit enter.(space between bootrec and / )
  4. The installation process will repair the boot sector.
5/20/2009 12:04:26 AM • Gateway ML3706... • Answered on May 20, 2009
I have the application SuperSU the free edition on my phone and everytime I try to use it to root my phone forwards me to an address on Chrome the simply says 502 bad gateway
you can use kingroot to root your phone. and some root apps might harm yor os i suggest you not to root your phone
3/1/2024 4:28:21 PM • Gateway... • Answered on Mar 01, 2024
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor. The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port. I hope this helps. Cindy Wells
1/18/2024 10:32:24 PM • Gateway... • Answered on Jan 18, 2024
I have a gateway Zx4931 and the power button is not working. Do I need to replace the power button or can I reconnect the wires?
Re connecting the wires may work without issues.
12/26/2023 5:46:39 PM • Gateway... • Answered on Dec 26, 2023
Do i need a driver for old gateway gmax2000 speakers connected to an old acer-based home built pc my nephew gave me?
No you don't need a driver. These are very plain powered speakers that come with a mains adapter and a lead with a 3.5mm stereo jack at both ends. Plug one in the speaker and the other into the headphone jack on the front or the speaker socket on the back which will either be a socket on the motherboard, or if your son put a sound card in the computer, it will be in a sound card. If it doesn't play straight away, go into Settings - Audio and make sure the sound card or the On-Board Audio is enabled. This shows the cable https://picclick.com/Vintage-Gateway-2000-ACS41-Altec-Lansing-Multimedia-Computer-314990339798.html#&gid=1&pid=1 More here https://www.google.com/search?q=gateway+gmax2000+speakers ..
11/29/2023 12:20:06 AM • Gateway... • Answered on Nov 29, 2023
WATTS REQUIRED FOR GATEWAY LAPTOP NV55C
110 watts for the power supply.
11/21/2023 1:16:48 AM • Gateway... • Answered on Nov 21, 2023
Gateway ML3706 Notebook Logo
18 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ML Gateway
  • ML Gateway
Most Popular Question
gateway laptop will not turn when push
  • Computers & Internet
