20 Most Recent
Dell Inspiron E1705 (DNDWGA3) PC Notebook Questions & Answers
Upon hitting the power button, The power light stays solid, Screen stays dark, Hard drive stays solid for a shortl time then turns off, Num lock stays solid and caps and scroll locks flash continously
sure old post and 12 year old PC. (relic, we use dog years on LT)
you did it wrong, the tests. here is the order (&matters)
- main battery huge out, they short, remove it forever if you want.
- next this PC is today 12 years old and no RTC coin cell lasts 12years, below 2.9vdc it bad , did you forget this? why?
- rule one says the pink bunny, after 7 years get ride of COIN.!!!
- next is AC powerpack only, and the correct one and voltage and 100watts is best on old hot running PCs did you get this wrong ? a $15 cheap fix too, having full power to run this pig.
- Learn that old CPU and old GPU (omg both) waste huge power and heat, due to a verse Moores law effect. (google it)
- next is Fans they must run or there is no power, BIOS runs the fans if BIOS is dead fans will be dead, means no power in the PC.!!!! or shorts.!!!!
- The GOAL first is not windows or linux it is in fact BIOS. BIOS screens must all work even with HDD out. and sure DVD drive out.
- we next remove optional modules from the mobo. like wifi, modem dial up; useless card, and all ram tested ram 1 by 1, we then remove SD readers or card readers from MOBO and quite frankly all models NOT CPU/GPU. see if one module is shorted. we do, that and expect that, after all things do short, when they do the VRMs regulators SHUT DOWN ending that FIRE thing.
- there is more, if confused have a real shop fix it. they know these ropes. (electronics testing and isolating bad parts)
I have dell 1545 , the screen was broken and when
plug in an external monitor and power on the lappy,,,you may have to press the fn key and the appropriate function key to switch display to external,,,should you have a diplay on the external,,,you more than likely got a bodgy screen or damaged it in transit or instal
Dell inspiron laptop screen colours inverted (negative)
if the same issue occurs in the BIOS your soluton is to have your LCD screnn replace or have your LCD inverte cable checked/replaced ^_^ this has nothing to do with the BIOS vodeo card drivers do not function in the BIOS to be able to do such in the BIOS screen
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
How to delete bookmarks
google dead ?
first off my PC has 4 browsers.
all 4 different answer.
IE11 ( or OMG 1 to 10 )
Edge
Chrome.
Firfox v95 (click tab book marks then click manage BM, the right click any or all you see and delete.
learn google
like
google IE11 bookmarks delete.
and read, millions of hits world wide all true.
