20 Most Recent Whirlpool GEQ8858H Dryer Questions & Answers
Im need help figuring out how to connect wires to
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
6/19/2011 9:21:45 PM • Whirlpool... • Answered on Jun 19, 2011
The stock number is IED4400SQ0 The
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
6/19/2011 9:19:09 PM • Whirlpool... • Answered on Jun 19, 2011
My dryer's belt broke and I cant find the part
WE12X1001, WE12X1000, WE12M29 are the three different belts used on GE Dryers and if you go to
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher and do a search on these parts you will be able to purchase them directly from GE. You will need to look at your belt and pull the number off if your belt in order to assure you get the right one. If you require further assistance, please do not hesitate to ask.
6/14/2011 6:33:28 PM • Whirlpool... • Answered on Jun 14, 2011
My clothes dryer fuse blew and has now been
Hi.
the heating element is tested removing it from circuits and reading impedance at its terminals. If the element is bad, then circuit will be open (Ohms stay on infinity).
Rather than the heating element you should replace the thermostats kit. Thermostats are also tested reading Ohms. When a thermostat is good it must read zero or very low impedance at room temperature. The thermal fuse is tested in the same way, I do not know if you already replaced this part. Check the termal fuse first.
Here parts and diagrams:
One Time Use Thermal Fuse (part 7 in diagram)
CUTOFF-TML (Thermal Cut-Off Kit) (part 9)
High Limit Thermostat(part 15)
Cycling Thermostat (part 8)
Heating Element (part 17)
Here the diagram, click on picture to enlarge:
9/11/2010 4:01:30 PM • Whirlpool... • Answered on Sep 11, 2010
Dryer not running.If you jiggle the timer it come
It sounds like you have a loose wire on the timer. Unplug the machine and remove the vented piece of metal from the back top (where you would expect the back of the timer to be) make sure all connections are secure. if they are and problem continues, you will need to replace the timer.
Please rate this answer for me. Thank you
3/26/2010 12:44:46 AM • Whirlpool... • Answered on Mar 26, 2010
DRYER NOT GETTING HOT
CHECK THE FOLLOWING--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
5/31/2009 11:52:14 PM • Whirlpool... • Answered on May 31, 2009
Whirlpool WGD4800XQ1 Dryer-- Replaced burner coils and it worked great. The next day no ignition again.
There are about seven different possiblities and the prospective solution in each case appears to be replacement of a different part! I suppose if you have the proper testing equipment for assessing each of those parts, you might be favored with a relatively inexpensive fix. I would be embarassed to suggest you replace all in sequence until the dryer works. Thermal Fuse: The thermal fuse is a safety mechanism that prevents the dryer from overheating. If it blows, the dryer won't heat. Check if the thermal fuse is intact and replace it if necessary. Cycling Thermostat: The cycling thermostat regulates the temperature inside the dryer drum. If it's faulty, the dryer may not heat properly. Consider checking and replacing the cycling thermostat. Igniter: The igniter is responsible for lighting the gas burner. If it's defective, the dryer won't ignite. Inspect the igniter for any signs of damage or malfunction. Gas Valve Coils: Although you've already replaced them, double-check the gas valve coils. Sometimes, even new parts can fail. Ensure they are securely connected and functioning correctly. Ventilation: Poor ventilation can lead to longer drying times and affect ignition. Make sure the dryer vent is clean and not obstructed. A clogged vent can cause overheating and affect ignition. Door Switch: The door switch ensures the dryer doesn't operate when the door is open. If it's faulty, the dryer won't start or heat. Verify that the door switch is functioning properly. Timer and Controls: Check if the timer advances correctly during the drying cycle. Malfunctioning controls can impact ignition. Inspect the timer and control board for any issues. Whirlpool Dryer WGD4800XQ1 - OEM Parts & Repair Help - PartSelect.com
4/4/2024 12:10:04 AM • Whirlpool Dryers • Answered on Apr 04, 2024
On a cabrio whirlpool dryer what does E4 and F4 codes mean
A "F4E4" (Low or No Line Voltage) code indicates there may be a problem with your home power supply, keeping the dryer's heater from turning on. The dryer will continue to run when this diagnostic code is present. Touch any pad to clear the code from the display and return to the estimated time remaining.
1/20/2024 7:55:51 AM • Whirlpool Dryers • Answered on Jan 20, 2024
How do I remove and replace an Amana Whirlpool clothes dryer start switch?
Push to start relay switch. NOTE: If the dryer will not start check the thermal fuse before ordering start switch. The switch is often not the cause of the dryer failing to start. pull the knob off the switch the answer should be visible
1/9/2024 4:54:28 PM • Whirlpool Dryers • Answered on Jan 09, 2024
Whirlpool Duet Dryer Won't Start
possible bad motor
11/5/2023 4:38:01 AM • Whirlpool Dryers • Answered on Nov 05, 2023
Whirlpool ED9270XW1 dryer when you hit the start button, the dryer will not start?
Never 'hit' the Start Button, always press it gently. It is part of the main control board. Whirlpool dryers can be reset by disconnecting the power from the wall socket overnight. Apart from that, you would need to disassemble it and check the Thermal Cut Out, the Thermal Fuse and the Thermostat with a digital multimeter.
Is There a Reset Button for Whirlpool Dryers?
Hunker https://www.hunker.com > ... > Washer & Dryers This is done by pressing "Start" for a few seconds to restart the dryer. If the dryer does not restart automatically, select a new cycle and any options then ... ..
10/21/2023 8:31:28 PM • Whirlpool Dryers • Answered on Oct 21, 2023
Whirlpool WED7500GW0 dryer. How do I remove a whirlpool dryer back panel please?
Question edited for clarity. You normally get inside them from the top and front. What are you trying to do? That is the important part! This gives generic advice https://www.google.com/search?q=whirlpool+dryer+wed7500gwo+belt+replacement ..
9/22/2023 2:31:32 AM • Whirlpool Dryers • Answered on Sep 22, 2023
E1 Error on Whirlpool Duet Dryer GEW9250PL1
wow, that is a tale of woe. Well E1 is definitely the thermistor, but you can check it with a multimeter. It may be a bad batch, or it could be the wiring. You should never replace components on guesses, fuses and elements are an easy test. The remanufactured board may also be at fault. The unscrupulous take them off machines, clean them and sell them on untested. https://www.google.com/search?q=E1+Error+on+Whirlpool+Duet+Dryer ..
9/1/2023 3:45:56 PM • Whirlpool Dryers • Answered on Sep 01, 2023
Whirlpool gas dryer GGW9250PW0. In diagnostics I get 88; open door and get 69. My problem is that the dryer doesn't start at any setting and stays on sensing. Thermal fuse and thermistor are good
It is a GAS dryer, that means you can't work on it yourself. Only registered qualified gas technicians can work on gas appliances and that is the law. Plus, if it is the main control board, you want professional diagnostics due to the cost of them.
8/6/2023 12:26:21 AM • Whirlpool Dryers • Answered on Aug 06, 2023
Whirlpool duet model YWED9300VU0
Try kit 4392067. It's the 4 roller wheel kit with belt and pulley. I use them all the time on that model, but without the Y in the beginning. Not sure what the variation is there.
8/3/2023 3:40:43 PM • Whirlpool Dryers • Answered on Aug 03, 2023
How do I remove the top of a Whirlpool Cabrio dryer WED5600XW0 to replace the door switch? The lint trap is under the door. I don't see the clips.
Aha, a new question Meri. Not 'lifting the LID', 'removing the TOP' of the Dryer. The videos show the job.
7/21/2023 2:17:47 AM • Whirlpool Dryers • Answered on Jul 21, 2023
2answers
Dryers Logo
Popular Tags
9 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
dryers belt broke find part
  • Dryers
