20 Most Recent
Research In Motion Crystal Case For Black Berry Curve 8330 Made With Swarovski Elements Questions & Answers
BLACK BARRY 8520 COUNTRY CODE UNLOCK
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue:
Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists.
Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery.
Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process.
Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues.
https://www.manua.ls/stanley/bc15bs/manual
If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM •
Cell Phones
Answered
17 hours ago
I need the reset code for Cash Power 2000 prepaid electricity meter.
How do I reset my cash power meter?
Reset your meter by pressing I, BLUE or # button, this is needed to ensure the 2 parts of your meter initiate connection again. This action should reset your meter. Please note, this error is not a technical error and you should never insist a technician comes out for this.
4/17/2024 6:33:31 AM •
Cell Phones
Answered
2 days ago
GPX Media Player model MT851B. My touchscreen doesn't respond on it. How do I fix it
There doesn't seem to be anything online to suggest how to do a reset or recalibrate the screen.
You could try three things
Look for a tiny Reset hole in the back.
Connect it to a computer and in Windows Explorer see if the is any useful right click commands?
Or leave it running until it runs out of power, wait 24 hours before recharging.
4/9/2024 3:30:50 AM •
Cell Phones
Answered
on Apr 09, 2024
