20 Most Recent Whirlpool LGR6636 Gas Dryer Questions & Answers
2answers
Gas dryer will not stop running and has no heat
The sensors will not shut down the dryer until the dampness goes away and if you have paid the gas bill, I would assume the gas carrying apparatus within the machine has gone haywire. Quite simply when the clothes are wet the control klixon sends current to the gas assembly. Within the gas assembly is the flame sensor, the igniter and the gas operator solenoids. The power is fed first to the sensor and then to the igniter. The coils also are hot and on the same circuit. Those coils won't open the gas valve because of the enormous rate of power it takes to fire up that igniter. The flame sensor has a bi-metal within it that determines the heat of the igniter and when the temperature reaches 1800f then the sensor shuts down power to the igniter and all of the energy is toosed in the direction of those solenoids. They snap down and yank the spring loaded gas valve open and fuel flows outward right onto the screaming hot igniter. Houston we have ignition. So what can go wrong? If the fuse is blown due to excesive lint or blocked air flow then no power will get to the gas assembly. If the power is getting there then if the sensor is open the igniter wont glow. Since the silicon carbide igniter becomes a resister in the same circuit when the flame hits it, the gas coils themselves will not fire off if the igniter is faulty. The solenoids themselves will get hot and quit,cool down and work some more. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
10/14/2009 2:52:10 AM • Whirlpool... • Answered on Oct 14, 2009
2answers
Whirlpool gas dryer LGR6636PWO heats for appro. 5
First check the exhaust vent and connecting vent material for a clog. If vent is OK,replace the gas valve coils.
10/4/2009 8:46:57 PM • Whirlpool... • Answered on Oct 04, 2009
Whirlpool gas dryer wont heat up
Hi!!! you seem to have a problem with the coil boosters..located above the gas valve..Its shown here .Good luckk..8035205.jpg
1/21/2009 3:12:04 AM • Whirlpool... • Answered on Jan 21, 2009
Whirlpool WGD4800XQ1 Dryer-- Replaced burner coils and it worked great. The next day no ignition again.
There are about seven different possiblities and the prospective solution in each case appears to be replacement of a different part! I suppose if you have the proper testing equipment for assessing each of those parts, you might be favored with a relatively inexpensive fix. I would be embarassed to suggest you replace all in sequence until the dryer works. Thermal Fuse: The thermal fuse is a safety mechanism that prevents the dryer from overheating. If it blows, the dryer won't heat. Check if the thermal fuse is intact and replace it if necessary. Cycling Thermostat: The cycling thermostat regulates the temperature inside the dryer drum. If it's faulty, the dryer may not heat properly. Consider checking and replacing the cycling thermostat. Igniter: The igniter is responsible for lighting the gas burner. If it's defective, the dryer won't ignite. Inspect the igniter for any signs of damage or malfunction. Gas Valve Coils: Although you've already replaced them, double-check the gas valve coils. Sometimes, even new parts can fail. Ensure they are securely connected and functioning correctly. Ventilation: Poor ventilation can lead to longer drying times and affect ignition. Make sure the dryer vent is clean and not obstructed. A clogged vent can cause overheating and affect ignition. Door Switch: The door switch ensures the dryer doesn't operate when the door is open. If it's faulty, the dryer won't start or heat. Verify that the door switch is functioning properly. Timer and Controls: Check if the timer advances correctly during the drying cycle. Malfunctioning controls can impact ignition. Inspect the timer and control board for any issues. Whirlpool Dryer WGD4800XQ1 - OEM Parts & Repair Help - PartSelect.com
4/4/2024 12:10:04 AM • Whirlpool Dryers • Answered on Apr 04, 2024
On a cabrio whirlpool dryer what does E4 and F4 codes mean
A "F4E4" (Low or No Line Voltage) code indicates there may be a problem with your home power supply, keeping the dryer's heater from turning on. The dryer will continue to run when this diagnostic code is present. Touch any pad to clear the code from the display and return to the estimated time remaining.
1/20/2024 7:55:51 AM • Whirlpool Dryers • Answered on Jan 20, 2024
How do I remove and replace an Amana Whirlpool clothes dryer start switch?
Push to start relay switch. NOTE: If the dryer will not start check the thermal fuse before ordering start switch. The switch is often not the cause of the dryer failing to start. pull the knob off the switch the answer should be visible
1/9/2024 4:54:28 PM • Whirlpool Dryers • Answered on Jan 09, 2024
Whirlpool Duet Dryer Won't Start
possible bad motor
11/5/2023 4:38:01 AM • Whirlpool Dryers • Answered on Nov 05, 2023
Whirlpool ED9270XW1 dryer when you hit the start button, the dryer will not start?
Never 'hit' the Start Button, always press it gently. It is part of the main control board. Whirlpool dryers can be reset by disconnecting the power from the wall socket overnight. Apart from that, you would need to disassemble it and check the Thermal Cut Out, the Thermal Fuse and the Thermostat with a digital multimeter.
Is There a Reset Button for Whirlpool Dryers?
Hunker https://www.hunker.com > ... > Washer & Dryers This is done by pressing "Start" for a few seconds to restart the dryer. If the dryer does not restart automatically, select a new cycle and any options then ... ..
10/21/2023 8:31:28 PM • Whirlpool Dryers • Answered on Oct 21, 2023
Whirlpool WED7500GW0 dryer. How do I remove a whirlpool dryer back panel please?
Question edited for clarity. You normally get inside them from the top and front. What are you trying to do? That is the important part! This gives generic advice https://www.google.com/search?q=whirlpool+dryer+wed7500gwo+belt+replacement ..
9/22/2023 2:31:32 AM • Whirlpool Dryers • Answered on Sep 22, 2023
E1 Error on Whirlpool Duet Dryer GEW9250PL1
wow, that is a tale of woe. Well E1 is definitely the thermistor, but you can check it with a multimeter. It may be a bad batch, or it could be the wiring. You should never replace components on guesses, fuses and elements are an easy test. The remanufactured board may also be at fault. The unscrupulous take them off machines, clean them and sell them on untested. https://www.google.com/search?q=E1+Error+on+Whirlpool+Duet+Dryer ..
9/1/2023 3:45:56 PM • Whirlpool Dryers • Answered on Sep 01, 2023
Whirlpool gas dryer GGW9250PW0. In diagnostics I get 88; open door and get 69. My problem is that the dryer doesn't start at any setting and stays on sensing. Thermal fuse and thermistor are good
It is a GAS dryer, that means you can't work on it yourself. Only registered qualified gas technicians can work on gas appliances and that is the law. Plus, if it is the main control board, you want professional diagnostics due to the cost of them.
8/6/2023 12:26:21 AM • Whirlpool Dryers • Answered on Aug 06, 2023
Whirlpool duet model YWED9300VU0
Try kit 4392067. It's the 4 roller wheel kit with belt and pulley. I use them all the time on that model, but without the Y in the beginning. Not sure what the variation is there.
8/3/2023 3:40:43 PM • Whirlpool Dryers • Answered on Aug 03, 2023
How do I remove the top of a Whirlpool Cabrio dryer WED5600XW0 to replace the door switch? The lint trap is under the door. I don't see the clips.
Aha, a new question Meri. Not 'lifting the LID', 'removing the TOP' of the Dryer. The videos show the job.
7/21/2023 2:17:47 AM • Whirlpool Dryers • Answered on Jul 21, 2023
2answers
Whirlpool duet dryer not working.... HELP! GEW9250PW1
You didn't give the Model # but I brought up this site and each part has a replacement video with it. https://www.repairclinic.com/Shop-For-Parts?query=WED8740DW If incorrect Model just imput your's and go from there. Best to you.
6/23/2023 5:41:39 PM • Whirlpool Dryers • Answered on Jun 23, 2023
Taking front panel off Whirlpool Wed5100 dryer
Check here and watch video on thermal fuse replacement... https://www.repairclinic.com/ProductDetail/697009 Best to you.
6/18/2023 2:49:33 PM • Whirlpool Dryers • Answered on Jun 18, 2023
Whirlpool LGR6636 Gas Dryer Logo
5 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
gas dryer will not stop running no heat
  • Dryers
