20 Most Recent LG GSA-H22N DVD±RW Dual Layer Burner Questions & Answers
0answers
I want to burn a karaeoke disc
The problem isn't the burner. You need karaoke software to burn and view cdg files. Below is a link to free karaoke software. Install the software (or a software package of your choosing) and re-burn your files.Karaoke Builder
1/3/2012 3:29:20 PM • LG GSA-H22N... • Answered on Jan 03, 2012
Whenever i insert a dual
Hi sadh_priyank
Check this in the following order :
You are using a program set to 4.5 GB or your device is set to 4.5 GB or you are using an unappropriate disc .
Best regards ,
fanaudi .
6/30/2011 1:04:34 PM • LG GSA-H22N... • Answered on Jun 30, 2011
Burn Completed Successfully" but files not shown
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions or just replace them there probably bad/faulty
hope this helps
11/15/2010 7:03:04 AM • LG GSA-H22N... • Answered on Nov 15, 2010
The dvd door fail to open
To open this drive you can open My Computer and right click your DVD drive and select eject. You can also open any CD/DVD drive by taking a paper clip (or something the size of one) and inserting it inside the tiny pinhole near the eject button on the drive.
1/13/2010 11:14:06 PM • LG GSA-H22N... • Answered on Jan 13, 2010
DVD burner will not recognize blank DVD's now
Did you try using Nero or Roxio? Don't only rely on the standard Windows support for CD/DVD writing.
Did you connect the new hdd the same way as the old hdd, or did you add it to the same cable as the CD/DVD writer perhaps? If multiple IDE devices are on the same cable, the master slave setting can cause problems. If you are using SATA devices, that should not be a problem.
Drivers are not required for IDE devices, including most CD/DVD writers, so don't bother with that.
11/11/2009 7:15:04 PM • LG GSA-H22N... • Answered on Nov 11, 2009
2answers
LG GSA-H22N DVD-RW Dual Layer
Remove, then reinstall the burner's drivers...accordianman
1/23/2009 10:13:05 PM • LG GSA-H22N... • Answered on Jan 23, 2009
HL-DT-ST- DVD-RAM GSA-H22N
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
12/29/2008 10:58:57 PM • LG GSA-H22N... • Answered on Dec 29, 2008
Dvd burner no worky.
Disconnect completely your driver and do the connection again from stratch! May work ! REG clean and Verify Disc before reinstalling! Good luck!
12/26/2008 11:26:33 PM • LG GSA-H22N... • Answered on Dec 26, 2008
2answers
DVD region
You miss-understood. AnyDvd copies directly from the DVD drive to the hard disk, and removes region info as it does. Then a backup DVD can be created from the image file. The image file can also be accessed by DVDShrink to alter the size to fit.
12/26/2008 11:23:57 PM • LG GSA-H22N... • Answered on Dec 26, 2008
2answers
DVD writable media not recognized by drive... shows up as "Blank CD"
lol a blank DVD cant be opened directly in Win xp, you need to use a DVD burning tool... for your laptop did you check you the DVD-ram reads cd's also?
10/23/2008 1:13:41 AM • LG GSA-H22N... • Answered on Oct 23, 2008
Which DVD Writer to buy!
i prefer lg dvd writer
7/23/2008 4:16:12 PM • LG GSA-H22N... • Answered on Jul 23, 2008
Unable to copy DVD
no solution
please use no scracth dvds
7/21/2008 12:28:15 PM • LG GSA-H22N... • Answered on Jul 21, 2008
My dvd burner doesn't burn dvds
Try NTI burning software - Ihave had no problems with theirs.
http://www.ntius.com/
7/1/2008 11:51:49 PM • LG GSA-H22N... • Answered on Jul 01, 2008
DVD region
Try AnyDVD to convert the files.
7/1/2008 11:47:46 PM • LG GSA-H22N... • Answered on Jul 01, 2008
Freezing computer
Right now, your best bet is to try and remember the last time all ran well and run a system restore....accordianman
2/29/2008 5:57:50 PM • LG GSA-H22N... • Answered on Feb 29, 2008
DVD WRITER NOT WORKING
It sounds like you don't have the proper driver installed for that device. Without the appropriate driver your software will not be able communicate with the device properly.
1/6/2008 3:30:21 PM • LG GSA-H22N... • Answered on Jan 06, 2008
LG GSA-H22N DVD±RW Dual Layer Burner Logo
25 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GSA LG
  • GSA LG
Most Popular Question
hl dt st dvd ram gsa h22n
  • Computers & Internet
