20 Most Recent
Samsung WriteMaster SH-W162C DVD?RW Dual Layer Burner Questions & Answers
I need help.
clean lence once atime. which we use to clean dvd deak . it is similar as cd or dvd.
10/9/2009 9:58:34 AM •
Samsung...
Answered
on Oct 09, 2009
Please help me whit my cd\dvd writer...i need the drivers to that
this problem occurs dur to a registry entry
so try this
Click Start, and then click All Programs.
Click Accessories, and then click Run.
Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Exit Registry Editor.
Restart the computer
8/28/2009 5:40:24 PM •
Samsung...
Answered
on Aug 28, 2009
Not install the drive icon
Just check the power cable is properly connected to the drive , check all the pins from motherboard end and from drive end , if all are found to be ok then change the cable, if after cahnging the cable the problem not solved then change the drive .
5/26/2009 9:30:11 AM •
Samsung...
Answered
on May 26, 2009
Pc slows down
may be by a virus or cd writer lens is corrupt
1/20/2009 9:56:51 AM •
Samsung...
Answered
on Jan 20, 2009
Dvd writter not working
if the device is set up as a master and not a slave device it may be interfering with the hard drive. check the jumpers on the back of the device. If it's plugged into the same cable as the hard drive it must be a slave device. Otherwise, check your bios upon bootup to see if you it's trying to boot from the device instead of from the hard drive.
11/30/2007 9:19:13 PM •
Samsung...
Answered
on Nov 30, 2007
Samsung dvd sh893m
open the sh893m than get the hdd and reformat it when done put it back in the sh893m make sure u have a dvd+r with the latetst firmware on it so that the software can be rewritten
How do I find the instruction manual with codes for my Samsung 32" curved screen monitor ?
Manufacturer's Website: Go to the manufacturer's website (visit the official Samsung website in this case). Click on the support section, search your monitor model by product name or model number, and download your monitor model for the user manual. User manuals usually list codes and other relevant information.
User Manuals Online: Many people post user manuals online for all types of electronic devices and peripherals. You can search for your monitor and look for the user manual at sites such as ManualsLib, ManualsOnline, or Retrevo. Most of these sites will catalog user manuals for a wide variety of devices posted online by users and are normally free to access.
Physical User Manual: If you still have the original box or packaging with your monitor, there might be a copy of the user's manual in that box or enclosed. It might be in an actual printed booklet or perhaps just some links to online resources. Check under a section entitled 'Remote Control Codes' or 'Setup Instructions'.
Contact Samsung Support: If no luck finding it to download or to help you, there is contact support available, they should know where that information is, and be able to send it to you or refer you.
With these, you should be able to find the user manual for your Samsung 32" curved screen display and enter those codes.
4/13/2024 10:32:28 AM •
Samsung...
Answered
on Apr 13, 2024
Maquina de lavar Samsung wf90f5e5u4w
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Steam Wash, Washers Support ' Samsung Care US
Samsung
https://www.samsung.com > washers > front-load > ste...
Get the latest drivers, manuals, firmware, and software. Learn more. Request repair service. Arrange for a service visit at home, schedule a walk- ...
https://www.google.com/search?q=Samsung+DC92-01240C+service+manual
12/4/2023 10:19:25 PM •
Samsung...
Answered
on Dec 04, 2023
