Try GT Recovery for Windows!
GT Recovery for Windows is a professional data recovery for Android phone or tablet. It can restore deleted photos,videos,audios,documents from Android SD card and internal memory. Whenever you lost important pictures or deleted photos by accident, you can use it to scan and recover the images on your Android devices.
Here are the steps to recover deleted data on Samsung Galaxy S4.
With this way you can recover deleted data on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Download Link: http://www.gtrecovery.net/
Hi if you need sim network unlock pin you can visit this site Mobileunlocksolutions.com here you can get the sim network unlock pin and unlock your sony ericsson st25i easily. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email.
You can unlock your Sony Ericsson Xperia U or ST25I or Sony Xperia U phone using the unlock code.Visit the site Unlocking4u.com get code and unlock it easily.
I need to open my Xperia st25i but first i need to enter the SIM Network Unlock PIN... WHERE CAN I GET MY PIN: here is the IMEI of my Xperia U ST 25i : 35361045832930
I suggest you can approach Unlocking4u.com and specify the country,locked network of Sony Xperia U ST25i.Based on the availability you can get the unlock code along with free instructions.
Use unlock code to unlock your Sony Ericsson ST25i. Get the code from the site Prounlocking.com ,and unlock it using unlocking instructions which is given in the site itself.
Sonyhttps://community.sony.es > m-series > td-p
... Xperia Companion. This will do a clean installation of the latest ... August 2017.
August 2017. Keep getting " unfortunately UI has stopped working" message.
Question edited for clarity and make real words.
Settings > Accounts. Accounts, tap the name of the account that you want to synchronize with. A list of items appears showing what can be synchronized with the account. Tap the items that you want to synchronize.
Sonyhttps://community.sony.ee > xperia-archive > td-p
Select Sony Ericsson. To set up Sony Ericsson sync in your phone: 1. From the Home screen, tap the applications bar 2. Tap Sony Ericsson Sync > Get started 3 ...
The remote control code for Sony HBD-TZ510 home theater system may vary depending on the brand of the remote you are using. Here are a few common remote control codes that may work:
30158
31759
31939
31758
To program your remote, follow these steps:
Turn on your Sony HBD-TZ510 home theater system.
Press and hold the "Code Search" button on your remote control until the indicator light illuminates.
Press the "DVD" or "AUX" button on your remote to select the device you want to program.
Enter the four-digit code using the number buttons on your remote.
Press the "Power" button to test if the code is correct. The device should turn off if the code is correct.
If the device turns off, press the "Enter" button to save the code. The indicator light will turn off.
If the device does not turn off, repeat steps 4-6 with a different code until you find the correct one.
Note: If you do not have the original remote control that came with your Sony HBD-TZ510, you may need to purchase a universal remote control that is compatible with your device.
The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
Turn on your Sony DVD player.
Locate the code for your Sony DVD player in the code list provided with the universal remote.
Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
Enter the code for your Sony DVD player using the number buttons on the remote.
Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
Turn on your Sony Bravia TV.
Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
Enter the code for your Sony Bravia TV using the number buttons on the remote.
Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
Unless you have enabled the actual USB charge settings on the PSP you probably won't be able to charge it via a USB cable.
The simplest solution here is to buy a replacement mains charger. They are usually reasonably cheap to buy for a decent quality one. I personally would avoid the really cheap ones as they are not always as good a quality as an original Sony charger.
Another option is to buy a Docking Station for the PSP. Some of these are a table top stand that plugs into the mains electric supply. You then sit the PSP into it, attach a short power wire from the stand and leave it to charge as normal. There are other versions where you have to remove the battery from the PSP to charge it.
The batteries are actually quite easy to remove and replace so you could consider buying a spare battery as well as a backup.
