20 Most Recent
Virgin Mobile - Lg Optimus Elite Mobile Phone - Black Questions & Answers
My lg optimus elite keeps turning on and off how do i fix it
First, make sure if this problem appear after you install any APP, if so you can try to brush system to fix it.Else maybe the following cases:1, mobile phone motherboard leakage lead the current too large.2, The inside circuit protection of the lithium battery is too sensitive, so it power off when circuit is large.3, the battery itself is aging.4, Battery contacts are dirt-bit, causing bad power supply.5, The engagement between the battery and the phone is easy to loose bits.Of course, don't forget to see if the power button is back to its own place
Virgin mobile optimus elite outgoing email
If its the email app that came preloaded on your phone, the best thing to do is go on the play store and download the app that's with your email. Like if you have yahoo go get the yahoo app. The one that comes on the phone sucks there something that's not compatible with the software. I had the same problem with my galaxy nexus.
Stuck on start up screen, will not go to home screen
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
No ring sound
MY dear Your Phone Ringer Default So Please change RingerAnd Ringing Sound Problem will solved
Insert sim
check in other phones your sim card work or not?
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue:
Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists.
Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery.
Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process.
Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues.
https://www.manua.ls/stanley/bc15bs/manual
If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM •
Cell Phones
Answered
Yesterday
