20 Most Recent
Panasonic KX DT343-B Digital phone - Black Questions & Answers
How do I turn off message light on Panasonic KX-DT343 phone ?
There must be a user manual available as a PDF file that should enlighten you as we don't have the phone shown I don't think that I would know exactly how to do it as there is one of these phone at the centre that I go to I will have a tinker with it find out unless someone has changed the pin code which which would be just like them.
How do I record greetings in Day, Lunch and Night Modes?
This PBX system are you using? if it is an asterisk based pbx, you will need to do a GotoIf statement in extensions.conf.
GotoIfTime(09:00-18:00,,,?[labeliftrue][:labeliffalse])
If you are using UI based system, you can simply do it in the timegroup and timecondition page.
HOLD MUSIC TOO LOW
Look for the KXDT343-Digital.pdf on google should tell you what you want to know, I want to upload you the pdf files but the web fixya client won't let me so you will have to get them yourself
Telephone does not ring calls go directly to voice mail
So if your calling someone and it goes directly to voicemail that means that there is some shortage between the person you are calling and yourself. Wait around 30 minutes after calling that person to see if it works. If it doesn't work then call your phone company. This also works for vise versa.
How do I change the amount of rings before it goes into VM?
I think you would have to access the firmware via a terminal so if you know the quad ie.192.168.x.x 'x' being any number between 0-255 includeing zero and hitting connect then you should be able to access this stuff via the firmware menu.
How to get speaker phone to work on Panansonic KX-DT343
Download the Panasonic KX-DT343 users manual and a pdf and there should be what you are looking for if not then there must be something funny going on with the menu system but why not have a look in the settings to see if the intercom setup is there but I think you will find out what you want from the KX-DT343.pdf file.
How to recover erased voice mails
If the call has been erased then it can no longer be retrieved sorry erased recordings get written over so that is it I think you should not have deleated it and saved it instead.
