20 Most Recent
GE GSH25SGRSS Stainless Steel Side by Side Refrigerator Questions & Answers
How do I shut ice maker off
Lift the feeler bail above the ice, It should click and latch in the up position. It should not make any more ice till you put it back down.
Stuff is freezing in fresh food section
you probably have a bad fresh food sensor, but testing that is complicated for a homeowner, I would call for service and let them replace if necessary. probably 200 to 275 for the repair
A few days ago I
its not doing a defrost by itself you need to replace the defrost heater/defrost termination sensor/thermostat/defrost timer could be any one of these parts causing this problem you need to test each part with a multi-meter to determine what needs replacing.
No water comes out from the fridge
We will assume it has worked fine in the past and then slowly it took longer and longer to fill your glass before it stopped.
The first thing to look at is the filter, when was it last replaced?
My GE gsh25sgrss has problem with the water
I can show you where and assist you in removal of the water filter for your model GSH25SGRBSS if you like or is there a problem like cross thread or the filter is stuck? Sea Breeze
Refrigerator side won't cool
its iced up and needs to be thawed. you can use a hair dryer and make it fast in say 2 hours. the freezer side is blocked from admitting cool air to the fridge side. your defrost timer may be defective or you had a real humid situation that caused it to ice up.
For a GE refrigerator model GFSF6KEX, how do you remove the ice tray? (Not the freezer drawer, just the tray.)
To remove the ice tray from your GE refrigerator model GFSF6KEX, follow these steps:
Empty the Ice: Before removing the ice tray, empty it of any ice cubes. This will make it easier to handle.
Locate the Ice Tray: The ice tray is typically located in the freezer compartment, usually near the ice dispenser or ice maker.
Grasp the Bottom Edge: Stand in front of the freezer and open the door. Grasp the bottom edge of the ice tray on the sides. Be cautious not to place your fingers near the opening at the bottom front part of the bucket where the crusher blades are located.
Lift Up the Front: Lift up on the front of the ice tray so that it clears the stops on the ice bucket rail.
Pull the Tray Forward: Pull the ice tray forward and out of the freezer compartment.
Reinstalling the Tray: To reinstall the ice tray, follow these steps:
Line up the flange pieces on the sides of the tray with the channels in the ice bucket rails.
As you push the ice tray all the way back, lift the front of the tray so that it clears the stops on the front of the ice bucket rails.
Verify that the tray is properly inserted by pulling it forward. It should hit the stops on the rail and not come out. If it does, push the tray further back.
Check for Misalignment: If you're unable to push the ice tray all the way back, it might be due to a misalignment between the back of the auger (located in the tray) and the prongs on the auger motor (mounted in the back freezer wall). To fix this:
Remove the ice tray.
Close the freezer door.
Press the dispenser for cubed or crushed ice; you should hear a snap.
Open the door again and reinstall the ice tray.
Remember to handle the ice tray carefully, especially if it's full of ice.
