20 Most Recent KitchenAid "KHHC2090sss Microwave Hood Combination / 30""" Questions & Answers
Sounds like you have one or more faulty micro-switches for the door. They are not expensive to get, but your service center will likely charge you a lot to fix it. If you are handy, you can pull the case off and replace them yourself.
KitchenAid... | Answered on Oct 18, 2016
Yes, unless a technician may have removed it during a previous service. It should be located behind the controller assembly, sometimes in a small envelope.
At my Web site, I have a video showing you how to remove a typical microwave controller in about 5 minutes.
http://www.microwavecontrol.com
if you have other questions, please feel free to contact me directly by email through the Web site or at pupista@gmail.com
KitchenAid... | Answered on Nov 14, 2019
Yes, it is probably a bad relay. Usually appliance techs just replace the whole control board, because those relays can be hard to find and buy.
KitchenAid... | Answered on Oct 14, 2019
Yes, it is most likely a bad relay on the control board.
KitchenAid... | Answered on Oct 05, 2019
Hi Jill, what the screen indicates is that the door is not closed
There are a number of internal contacts that have to be closed for the microwave to work
If any of them are wrong, they can give you that information.
Depending on the brand there may be between 2 or 3 contacts in the door area that generate that warning
Indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Jill, lo que te indica la pantalla es que la puerta no esta cerrada
Hay una serie de contactos internos que tienen que estar cerrados para que el microondas funcione
Si alguno de ellos esta mal puede darte esa informacion
Derpendiendo de la marca pueda haber entre 2 o 3 contactos en la zona de la puerta que generan ese aviso
Indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
KitchenAid... | Answered on Sep 12, 2019
KitchenAid "KHHC2090sss Microwave Hood Combination / 30""" Logo
Popular Tags
17 questions posted
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Microwave Ovens
Most Popular Question
our microwave not consistently come
  • Microwave Ovens
