20 Most Recent
IBM NetVista M41 PC Desktop Questions & Answers
Mouse only moves up and down not side to side
If it is a PS/2 mouse with roller ball, the horizontal wheel sensors are gone. No sense in trying to fix this roller ball PS/2 mice are really cheap. As far as the USB mouse you may have to install a driver. Depends on the operating system.
When system switched on it
Severe corruption - NTLDR is the program that launches the boot process. The only way to fix that is to reinstall.
How to rescue and recover IBM NetVista when I
When the computer boots, you should see a screen with something like this:
"To start the Product Recovery Program, press F11".
So, press the F11 key at that time and you should get steps to put your machine back in (more or less) factory condition (the software will be --- unfortunately, there's no such thing as a time machine for the hardware ;-)
If you have files you want to keep, BE SURE and back them up by copying them somewhere before you do this. In most manufacturer's "recovery" programs, the first thing they do is re-format the hard disk, so any files and programs you've installed since you bought it will be *GONE*.
Good luck with your recovery!
Won't boot.
Try to repair the operating system using windows xp cd
How can i tell what model computer I have
Hey there, I got an easy way for you to find everything you need to know about your computer. Go to the following link and download and install belarc advisor. When you run it, it will bring up a page with all the info you need listed.
Good Luck
seth
http://www.belarc.com/Programs/advisor.exe
Motherboard changover
It seem that everything is working except for the monitor or perhaps the on board video.
I would try a different monitor, if that does not resolve the issue. I would try installing a new video card. If you do try this, you will need to disable the on board video through the BIOS at start up.
I hope this helps,
Eric
How can i tell what model of computer?
hi, usually pc's has stickers on it, either on the tower or on the monitor, u could actually for the sticker first....opening tower is actually not recommended unless assisted by a tech besides yoll just get hardware info by doing that....to know the software i suggest just look for the stickers on the tower, hope you'd find out soon
Vga driver
Hello...maybe you can go to the control panel and use the "add new hardware" function and see if your windows support your screen...than you can use pnp or manual installation....you can select from a list... and in some cases it is better with a "generic" driver than none at all...i use my screen as pnp and it isn't.pnp ..under xp...works ok...don't forget to have your windows cd at hand ..yo may need it...plase tell me how it went...good luck...Ron
SyncMaster 753 DFX 17'' CRT show monochrome image
Oh vintage 386sx? In old graphics cards, there were DIP Switches to configure either to use as monchrome mode or color mode. Did you configure graphics card properly ? Moreover try using mode command to change monochrome to color.
IBM wheelwriter 6 only types when I press hard to the keys. Normal typing doesn't activate key strikes. Is there a sensitivity adjustment on the wheelwriter 6?
The IBM Wheelwriter 6 typewriter does not have a user-adjustable sensitivity setting for key strikes. However, the issue you're describing might be related to the keyboard mechanism, individual key switches, or the impact solenoid. Here are some steps you can take to troubleshoot and potentially resolve the issue:
- Clean and Lubricate: Over time, dust, dirt, and debris can accumulate inside the typewriter, affecting key movement. Try gently cleaning the keyboard area, especially around the key switches and mechanisms. Additionally, applying a small amount of appropriate lubricant to the moving parts might help improve key movement.
- Key Switches: Each key has its own mechanical switch underneath. If a key requires more force than usual to activate, it could be due to a worn or dirty switch. You might need to disassemble the typewriter to access and clean the key switches.
- Impact Solenoid: The impact solenoid is responsible for striking the print head against the paper to make an impression. If the solenoid is weak or sticking, it could result in the behavior you're describing. Try cleaning and lubricating the solenoid. If the problem persists, the solenoid might need to be replaced.
- Key Flex: The flex you feel in the keyboard might be contributing to the issue. If the keyboard has any physical damage or if the flex circuit is not seated properly, it can affect key activation. Carefully inspect the keyboard area for any visible damage or misalignment.
- Professional Repair: If the above steps do not resolve the issue, it might be best to seek the assistance of a professional typewriter technician. They have experience with these machines and can diagnose and repair mechanical issues more accurately.
I have a IBM personal computer Platinum III When I turn on my computer it starts normally but after that on my screen appears a text that says "System Error: tastiera Blocked" And after I can't continue to boot and it shows on my screen a error without a code...What should I do??
Tastiera indicated that you have a keyboard problem. Most desktops can't run without a working keyboard. (You need the keyboard connected and working during the power-on self test, POST.) Currently the motherboard can't communicate with the keyboard.
What is the model number for your computer? I don't recall a Platinum III, just a Pentium III. Is it a laptop or a desktop? What type of keyboard do you have (USB or PS/2 connector) or is it the built-in one of a laptop? Are you using some sort of converter/adapter for the connections? The USB to PS/2 converter for a mouse does not work with a keyboard. There are some USB to dual PS/2 converters available. However, they don't work with with all motherboards. What OS is installed on the system?
Try a different keyboard. (You should try a PS/2 keyboard if the system has PS/2 ports. If the OS is older than Windows 98 v. 2, then the USB ports are even more likely to not see the keyboard in POST.) If you use a USB keyboard, try different ports. If possible, make sure that the keyboards work on other machines. If it does, then I recommend replacing the system. The Pentium III is a ~20 year old CPU. That's certainly old enough to have major failures.
I hope this helps.
