20 Most Recent
Kenmore HE2t 3.7 cu. ft. Front Load Washing machine Questions & Answers
Kenmore he2t F25 error. Trying to ohm test the
Hello!
Most likely, error F 25 means that the aquasensor, the turbidity sensor of water, has failed.
Possible reasons of this error:
1) Perhaps there was a clog in the system of draining the water. Dirty water does not merge and because of this the sensor shows muddy water. It is necessary to clean the drain filter;
2) Lime or scale on the turbidity sensor. Always use high-quality washing powders or add descaling agent
3) Dirty water got into the plumbing. Drain all the water and run the wash program in hot water. The washing machine should be empty.
Wash Cycle will not start; add garment and door locked lights on.
IF you take the panel off the is below the door, there is a drain plug and you should take it out. YOU will get lots of WATER. Be ready. Clean this out and try again. The issue is most likely the water solenoid valve is bad or the board that controls it is bad. You can also find the tech sheet when you look for the drain. It has all the tests that you can run.
