20 Most Recent
Whirlpool LSN1000LW Top Load Washer Questions & Answers
Immediately after switching on my washing machine
hello,
what this f 65 code mean is an indication of loose of wire from the sensor reader from the connection
And the PE means that power error that is the loose wire will not allow the washer to carry out is function properly
what you need to do to fix up the problem is to unscrew (OPEN)the WASHER then trace the wire down to the power supply and also the panel connected to the screen clean all form of dirty and water on it fix up the wire that are disconnected from there position .
thank you and thank for using fixay.
9/30/2015 5:38:23 AM •
Whirlpool...
Answered
on Sep 30, 2015
Agitator movement
Hi, If this is a two piece agitator, start the wash cycle with no laundry in it and see if the lower half of the agitator moves. If the lower half works, you will need to change the dog kit inside the agitator. There is a 7/16" bolt under the agitator cap the will need removed to get the agitator out.
If the agitator does not move at all, It could be the coupler connecting the transmission to the motor. If the coupler is bad, tub will not spin the laundry dry.
I hope this helps you. Please let me know if I can assist you further.
Vic
9/12/2012 4:01:57 PM •
Whirlpool...
Answered
on Sep 12, 2012
Water wont drain form machine ....
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
10/2/2010 4:45:35 PM •
Whirlpool...
Answered
on Oct 02, 2010
When the machine turn to
It sounds to me as if the shipping restraints on the machine tub are still in. If so you will need to remove them. using the machine with them in will severely damage the transmission and tub assembly. This will also void the warranty. Go through your manual to be sure they have all been removed. If they have then check to ensure that the machine is level. If so then you may have a defective unit and need to contact the store that you purchased it from and discuss a refund or swap out. Hope this helps. Good luck.
9/5/2010 6:30:06 PM •
Whirlpool...
Answered
on Sep 05, 2010
Hello
my washing machine does not
If it works correctly all the way to the spin cycle the does nothing, its a 90% chance you have a ( Bad or Broken ) LID switch.. FOR SAFETY REASONS they design top load units so that they will not spin if the switch is bad .Gently lift up the lid a few inches then lower to close ,most of the time you should be able to hear a clicking sound when the lid is opened and closed if the switch is working properly,if no sound YOU NEED A LID SWITCH and easy item to replace Good luck
8/30/2010 8:20:55 PM •
Whirlpool...
Answered
on Aug 30, 2010
