20 Most Recent
Sylvania Meso Netbook Synet581 blue Questions & Answers
HOW DO I FIX A FAN PROBLEM COMPUTER IS VERY HOT
When a laptop starts to get very hot, its usually due to the airways between the fan and the outside being full of dust.You could buy a cooling bay, but i recommend you take the laptop to a local computer store to perform a cleaning of the same airways.
How do i change the batteries on my sylvania led wireless light ?
Depending on this style, there may be a cap on the end that you can remove and slide out the old batteries and slide in the new batteries. Be sure that they are facing the correct direction. Another style will have a bottom piece that turns a little bit and then comes right off exposing the three AA batteries.
7/4/2019 8:28:33 PM •
Sylvania...
Answered
on Jul 04, 2019
Connect sylvania netbook to wireless
You may have to turn on the wireless card with a Fn key combination on the keyboard. You also may need to enter the wireless password into the laptop if you haven't already.
4/21/2018 8:27:43 PM •
Sylvania...
Answered
on Apr 21, 2018
I can't get the batteries out of my Sylvania light flute
Hi
Normally the cap end which does not have the push button switch will unscrew. Then you can push the 4 lights and 3 battery housing out from inside the tube..BUT, mine are about 5 years old and would not slide out. I had to take a round blunt punch and hammer the housing through, out as the batteries were corroded inside aluminum and hanging on. It took a few wacks but did slide out. With a little care sanding the corrosion inside of the tube and battery contacts it went back together and still works.
4/16/2018 2:02:20 AM •
Sylvania...
Answered
on Apr 16, 2018
