20 Most Recent
Motorola Mobility Motorla MOTXT912 DROID RAZR Verizon 4G Smartphone Questions & Answers
Screen froze
Press power button and Down volume until phone powers down.
6/2/2014 4:07:56 AM •
Motorola...
Answered
on Jun 02, 2014
Will not turn on
make sure you have a stable internet connection, reboot the device and try again
1/11/2014 12:15:32 PM •
Motorola...
Answered
on Jan 11, 2014
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
1/2/2014 11:08:40 PM •
Motorola...
Answered
on Jan 02, 2014
How can i unlock motorola razor droid sim card for free
PUK Code PUK stands for Personal Unblocking Key. This is a unique eight-digit code specific to your SIM card. This is required when the PIN number to unlock your mobile phone is entered incorrectly 3 times. You are then given 10 attempts to enter your PUK code. If an incorrect PUK code is entered after the 10th attempt, you will block your SIM card permanently and will require a new SIM card from your mobile phone provider. PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack. If you do not have this then - Please contact your phone service provider. Your cell phone service provider can give you the PUK code once you give them your account details and they have confirmed your identity. For details to obtain the PUK code for the SIM card, please click on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
3/6/2013 1:06:03 AM •
Motorola...
Answered
on Mar 06, 2013
I charged my droid razr maxx to 100% then battery keeps dying within 15 minutes pls help
Hello My Dear Friend:"::First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
1/20/2013 7:22:31 AM •
Motorola...
Answered
on Jan 20, 2013
Washed my phone
take it all apart and let air dry completely then put back together.
11/5/2012 11:03:26 PM •
Motorola...
Answered
on Nov 05, 2012
Droid razr will not turn on
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
8/23/2012 3:04:16 AM •
Motorola...
Answered
on Aug 23, 2012
How to transfer photos from cannon d20 to computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
7/10/2014 1:12:57 PM •
Motorola...
Answered
on Jul 10, 2014
My schrin is upside down
All astronomical telescopes show the view upside down (and some have right/left inversion too) For terrestrial views, a erect image adapter is available but NOT recommended for astronomy as they reduce contrast.
12/18/2011 2:18:57 PM •
Motorola...
Answered
on Dec 18, 2011
Sim Network Unlock Pin Motorola
How to enter my Unlock Code on Motorola ?
Model : All Motorola
1 - Switch ON your phone with a not allowed SIM Card,
2 - Phone show "Enter Special Code",
3 - You can now enter the Unlock Code we send to you.
WARNING : If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody allready enter too many wrong codes, you just have to let phone ON on theses errors messages and after 40 min to 2 hours maximum the message "Enter Code Special" will appear again !
https://www.unlockbase.com/faq/en/Q_47.html
