20 Most Recent
3Com SuperStack 3 4228G 24-Port Ethernet Switch (0662705446844) Questions & Answers
3Com 3c17304 port 25 up not connecting
Well I think the port is bad, I had one that did something similar to your problem. I got on the 3Com website and submitted and RMA request and they upgraded my with the newest model. But if yours is still in stock they will replace with the same type. That is what I would do. Hope this helps ya.
How to check if the switch is manage or unmanaged
Managed switches you can enter the default ip into a web browser, login and "manage" settings" this default IP will be vendor specific. Unmanaged you just plug in devices and that's about it. Managed switches you will pay a lot more for. Some lower end ones maybe several hundred dollars and up. If you are buying switches at Best Buy they are almost all unmanaged.
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
