20 Most Recent HP Business Inkjet 1000 - Printer - colour - ink-jet - Legal - 1200 dpi x 1200 dpi - up to 23 ppm (m... Questions & Answers
indikator lampu tinta hitam menyala
HP Business... | Answered on May 16, 2013
you can try realigning the printer, first remove and plug the cartridges this may happen due to problems with the cartridges itself.. :)
HP Business... | Answered on Dec 18, 2010
Exactly what it says - the paper supply in the printer is out. Add more paper.
HP Business... | Answered on Aug 01, 2010
If you only just purchased your cartridge I would suggest you return the cartridge for an exchange. Unfortunatelty when a cartridge has expired the date is set inside the cartridges chip and so far I have not come up with a way to get around it. You will need to replace the cartridge with a new one.
HP Business... | Answered on May 28, 2010
the printer is pretty much in a Freeze state.. so turn off the printer.. remove the power cords.. keep it out for atleast a minute and then reinsert the connections back and then try to turn on ur printer.. it will surely resolve ur issue..
HP Business... | Answered on May 10, 2010
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
HP Business... | Answered on Mar 10, 2010
kindly re install the printer driver it will fix the problem.
Have a nice day and do not forget to rate please...!
HP Business... | Answered on Feb 02, 2010
The new cartridges comes with seal wrapper on nozzle, have you remove it or not, if you have already remove it the reinstall the ink cartridges and try to print.
Regards
Ashly82
HP Business... | Answered on Feb 01, 2010
have you installed the printer drivers ...... please install the driver first ...... post the comment if you are getting any error ....... if you installed the driver and still its not working please open the printer and faxes from the control panel and check your printer driver status ..it should be ready ....... please post your comment if you are getting any error ....so we can help you correctly ....
HP Business... | Answered on Jan 08, 2010
give print ... select your printer .... then go to preference it will open another window ...then go to .color tab ....select print in gray scale ......
HP Business... | Answered on Dec 04, 2009
Dear Sir, Welcome to Fixya Expert zone When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. Sometimes intermittent noises from the printer can be caused by the drive belt slipping over the gears. Clean and lubricat the bar with some silicon lubricant such as WD40 by spraying it on a paper towel and running it across the bar two or three times. I think it solves your problem.If you have any problem regarding this issue leave a comment or feedback,we were happy to assist you. Have a Nice Day
HP Business... | Answered on Nov 20, 2009
The pickup roller is problematic. First clean, then replace if necessary.
The part should be under $20.
To replace (from HP Support):
1. Unplug the power cord from the
printer, and allow the printer to cool.
2. Open the toner cartridge door, and
remove the toner cartridge.
3. Locate the pickup roller.
4. Release the small, white tabs on
each side of the pickup roller by
pushing them away from the roller,
and then rotate the pickup roller
toward the front.
5. Gently pull the pickup roller up and
out.
6. Position the new pickup roller in the
slot of the previous pickup roller.
Note Circular and rectangular pegs on each
side prevent you from incorrectly
positioning the pickup roller.
7. Rotate the top of the new pickup
roller into position until the white
tabs on each side of the roller snap
the roller into place.
8. Reinstall the toner cartridge, and
close the toner cartridge door.
9. Plug the printer in to turn it back on.
Hope this helps.
HP Business... | Answered on Aug 16, 2009
Change your system date to backward and you can use it again
HP Business... | Answered on Jun 09, 2009
HP Business Inkjet 1000 - Printer - colour - ink-jet - Legal - 1200 dpi x 1200 dpi - up to 23 ppm (m... Logo
Popular Tags
38 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
InkJet HP
  • InkJet HP
Most Popular Question
lampu indikator cartridge cyan amp
  • Office Equipment & Supplies
