20 Most Recent
Viking 48" 6 Burner, Grill Professional Series Dual Fuel Range - VDSC485-6Q Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
Am cleaning up my range
You can call Viking and they will know for sure.I would think,as it is of comercial quality,that there may be a wire or more on the back.Most likely to connect to an ANSUL system,a type of fire suppression.It could also be for a vent hood or some attachment like a rotisserie.You can call them at 1-888-VIKING1 (1-888-845-4641).
Viking model vdsc4874gss
small oven
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Is there a cleaning manual for my 6 burner/griddle viking range?
I have a product that I use to clean my burners and griddle with, it is made by ECOLAB and is called Greasecutter Plus. It doesn't hurt the range but it makes it look brand new, even my griddle comes completely clean. You just spray it on then let it sit for a bit then it wipes clean.
Both oven fans run constantly
3 to 4 hours is a long time. Get to the fans (behind the control panel)
and check the screens for dust. Chances are the screens are clogged with
dust and need to be cleaned so the fans can move air for cooling
better. I had this problem on my GE JTP14, and after cleaning just one
fan it can keep up with cooling the electronic area while the oven is
running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice
conductive screwdriver! Hope this helps!
WHO SUPPLIES VIKING PARTS i AM FROM cANADA on
You can try allvikingparts.com, they ship to Canada for about 20$. Total cost was part price (in my case an ignitor for 65$) plus shipping (20$) plus duty (14$). Way cheaper than if I had ordered the part locally. Arrived within a week or so to my door. Telephone 888 988-4546.
A tech who came to my house also gave me three other numbers - although I never tried any of them as I found the one above online ... these may be located in Calgary - not sure
1 800 914-4799
1 800 467-2665
1 800 451-4133
Viking recommneds a 13
they may recommend but you are still bound by the building code in your locality. what distance does your building code require. you may be able to alter your setup to meet the code.
Oven will not work
It sounds like the Thermostat is defective.
Element can be removed from the front of the unit, it does not need to be pulled
I have a viking rangetop
Check the amperage draw to the igniter, if it is over 3amps and no gas, first off check the valve on the manifold behind then control panel if the valve is open then check the wiring to the thermal valve if it is connected then it would appear that the thermal valve is defective.
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
