20 Most Recent
Whirlpool 17 cu. ft. / 481 liter Upright Freezer EV170NLSS Questions & Answers
Door will no vacuum seal closed
Are you sure compressor is running? If it is make sure the evap fan is running. You should be able to hear the fan when you open the door. If ypou do not hear a fan running then fan has gone bad. 4390914 and approx cost is rediculous in my mind but it is approx. 150.00 to 160.00 . Crazy for a fan motor.
Ice in bottom of upright freezer
Hello. The drain hose is freezing because the defrost water is not exiting as it should. Check the evaporation tray where the drain hose sends the water and you may find dust, dirt, a clog etc. which is impeding the normal flow of water. Regards, Joe.
Freezer's power is dead
check the plug itself may be melted. next check the cord itself at terminations inside the freezer compressor section. if it's plugged into a gfci try resetting the gfci receptacle. check breaker, may have tripped off.
