20 Most Recent Whirlpool 19.6 cu. ft. / 555 liter Upright Freezer EV205FXKQ Questions & Answers
2answers
The temperature alarm goes off randomly. It
If you just purchased the freezer 3 weeks ago, I would be calling the store and or the manufacturer, and have them send out a service man to fix it or replace it.
5/2/2017 6:16:16 PM • Whirlpool 19.6... • Answered on May 02, 2017
Motor or compressor keeps clicking on and off and will not get cold
I would suggest the compressor and or motor are failing. The reason the interior light is dimming when the relay connects the compressor is a larger than normal demand on the power supply, i.e drawing more current (amps) than it was designed to.
1/8/2014 10:54:38 PM • Whirlpool 19.6... • Answered on Jan 08, 2014
My freezer is not cold. The temperature dial reads
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Take care in solving the problem....
5/7/2011 7:20:47 PM • Whirlpool 19.6... • Answered on May 07, 2011
My freezer will not freeze. It only gets cool.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
4/23/2011 5:29:37 PM • Whirlpool 19.6... • Answered on Apr 23, 2011
Ice buildup in bottom. Poor cooling.
maybe freon overcharge or oil stuck up in the tube causing not to circulate the freon gas.
6/25/2010 4:08:49 PM • Whirlpool 19.6... • Answered on Jun 25, 2010
My upright freezer has a small amount of water
look at the bottom of your freezer, you will find a small hole or opening, it is a drain exit point of your defrosted water, try to clean it, maybe there is a small object bocking up the way or the hose all away down
11/6/2009 8:46:48 AM • Whirlpool 19.6... • Answered on Nov 06, 2009
Punctured gas line/ uses R-12
not very easily. Most freezers have the evaporator and condenser inside the wall of the cabinet and you cannot access them. If the puncture is in the condenser you can put in an exterior condenser however the parts break down for your model does not offer this option (:
4/8/2009 8:53:37 PM • Whirlpool 19.6... • Answered on Apr 08, 2009
Top Shelf of Freezer Not Cooling
sounds like you may have a refridgerant blockage in the system. it may need a regas to see if it can be unblocked, as this is not a quick job it may cost you but phone around on the cost/feasibility of it. it may be just as well to get a new or second hand freezer.
11/20/2008 5:54:21 PM • Whirlpool 19.6... • Answered on Nov 20, 2008
Whirlpool upright freezer is working fine but an alarm is sounding intermittently. It sounds different than the high temperature alarm. Can't find codes. What does it mean?
If your Whirlpool upright freezer is working fine but an intermittent alarm is sounding that is different from the high temperature alarm, it could indicate an issue with the door or the door switch. The alarm is designed to alert you if the door has been left open for an extended period or if the door switch is malfunctioning. Check the door seal to ensure it is tight and the door is closing properly. You can also try cleaning the door switch to see if that resolves the issue. If the problem persists, it may be necessary to contact a professional for further assistance.
2/14/2023 6:46:27 AM • Whirlpool... • Answered on Feb 14, 2023
Model UW8FDXB1EX Whirlpool Upright freezer
3/12/2022 12:53:50 PM • Whirlpool... • Answered on Mar 12, 2022
The question i asked has been answered, but is there actual diagrams that i could view to see how it's done?
THIS question is your only question here on Fixya dot com! https://www.fixya.com/users/gregg-j-ajamian You just need a good search query to find stuff like this. Cut out all the extraneous words and use the bare bones. Videos in the link https://www.google.com/search?q=whirlpool+upright+freezer+EV250NXTQ03+remove+the+drain+grommet ..
10/2/2021 5:34:32 PM • Whirlpool... • Answered on Oct 02, 2021
2answers
Hello awesome Fixya Experts! How do I disable the tones/alerts for my Whirlpool freezer (model WZF79R18DM00)?
There shouldn't be any 'jingly tone' at the end of every compressor cycle. You could be hearing something else making a sound after the compressor stops.
3/8/2021 2:35:38 AM • Whirlpool... • Answered on Mar 08, 2021
Model # WZF79R20DW00. Which snowflake is supposed to make it colder?
The larger one
11/30/2020 11:12:06 PM • Whirlpool... • Answered on Nov 30, 2020
My whirlpool upright freezer is beeping every minute
The door switch or door module is defective. or the door is not fully closed
5/10/2019 9:51:02 PM • Whirlpool... • Answered on May 10, 2019
Green light flashing onwhirlpool freezer
http://www.fixya.com/tags/freezer_green_light_flashing/browse/whirlpool
3/13/2019 10:40:02 PM • Whirlpool... • Answered on Mar 13, 2019
2answers
Model EVL201NXRQ05 serial eww4020663 WHIRLPOOL UPRIGHT FREEZER - Freezer which is having ice freeze on the bottom of the freezer. What can I do?
The defrost water from the melted frost (ice) collects in the bottom of the freezer. If there is no plugged up drain, then you must remove the water manually with a sponge and bucket after a defrost cycle.
1/24/2019 3:41:51 AM • Whirlpool... • Answered on Jan 24, 2019
Model EVL201NXRQ05 Serial EWW4020663 Freezer which is having ice freeze on the bottom of the freezer. What can I do? no plug.
If it’s in floor if freezer, you have a clogged defrost drain. If it’s on inside back freezer wall, it’s a defrost problem
1/23/2019 11:07:42 PM • Whirlpool... • Answered on Jan 23, 2019
My water connection trips power after the water is turned on for a while
The solenoids that operate the ice maker and the water dispenser in the door may be getting water internally. I would put a pressure regulator on the line of the pressure exceeds 30 PSI.
1/23/2018 5:01:53 AM • Whirlpool... • Answered on Jan 23, 2018
Whirlpool 19.6 cu. ft. / 555 liter Upright Freezer EV205FXKQ Logo
13 questions posted
Top Whirlpool Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Freezers
  • Whirlpool Freezers
Most Popular Question
motor or compressor keeps clicking off
  • Freezers
