20 Most Recent
Avaya Definity 8434DX Corded Phone Questions & Answers
I can't get the time
Its on a toggle switch. So hit menu, select time and day, do not hit exit, wait.If it goes away, you just shut it off do this again, and it should stay on.
The display screen on my Avaya 8434DX isn't
check that the power brick is plugged in to a wall socket with power. The brick is gray and sits in between your phone and the phone socket. It inserts power for the display. ensure that the green LED is lit on the power brick and cables are plugged in properly. If the power brick is faulty contact your maintainer to get a replacement
The display went out on my AT&T 84354dx. What
Hi
Check the power brick in between the phone and the wall socket for your phone connection. The brick provides power to the display. make sure there is power green LED should be lit and the cables should be plugged in properly
How do you change the time on an Avaya 5420 phone
Avaya Phone Change Date and Time
Avaya/Lucent Partner ACS Phone System
- Press Feature and dial 00.
- Press the left intercom button twice.
- To set the time, press # and dial 103. Enter the correct time using a 24-hour format.
- To set the date, press # and dial 101. Enter the correct date using MMDDYY format.
- Press feature and dial 00 to save.
My Avaya Partner (old system) voice mail is not working after a power outage.
Power surges damage electronics that power up devices. The surges push too much current into the units sensitive controllers and thus damage the units beyond repair.
As a system ages, it declines just like people and thus tend to break down gradually. Power surges just make electronics go faster down hill.
