20 Most Recent
Samsung VP-D361 Mini DV Digital Camcorder Questions & Answers
I have samsung mini dv video camer, i dont know
Here is the url for the Samsung support site for the camera picture on this problem.
http://www.samsung.com/ie/support/download/supportDown.do?group=homeentertainment&type=camcorder&subtype=minidvcamcorder&model_nm=VP-D361&mType=&dType=D&vType=R&prd_ia_cd=03110600&disp_nm=VP-D361
You'll find user manuals you can download there.
Connect to tv problem
The cable you describe should be the only cable that you need. You want to make sure that you switch to whichever input you connect to on your TV. If you are getting sound but no picture there may be a problem with either the input or your cable. Connect the cable to a different input to see if it works. If it does then the problem is with the input on your TV. If it doesn't work then there is something wrong with the cable. You may have to get it replaced at the place you purchased the camera from/
Re eject and D error.
This error is a mechanical
malfunction, try this:
- Eject
the tape.
- Set to
OFF.
- Detach
the battery.
- Reattach
the battery.
Here is a link to your manual:
Manual
Eject error R
Use different tape. Is the tape still attached to the feed spool, or has it become separated ?
Samsung VP-D361 Mini DV Digital Camcorder - have
will it close with out a tape in. if its not doing it with the tape in there is a motor that pulls down something cannot remember its name. so when the deck goes in it can lock in place and hit the switch. if the switch has been damaged it will just eject the deck again. has one swith to say tape in and other switch is for table loaded. sounds like the loaded one is at fault. happens if you leave a tape in for a long time and not been used.
