20 Most Recent
Samsung UN46C8000XFXZA UN46C8000 46 3D LCD TV Direct LED Questions & Answers
Half of my TV screen is 3D all the time
It's seem to be a T-Con board problem. If you don't deal with electronics repair, call to a service center. If you deal with it, first thing is to search for service manual or schematic diagram. For more articles on how to repair this issue visit jestine's yong blog.
Cheers !
10/9/2020 9:02:52 PM •
Samsung...
Answered
on Oct 09, 2020
My tv is a Samsung model UN46C8000XFXZA and like I said backlight are blinking and part of the screen is dark but I still have sound and picture
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts. .
10/28/2016 5:44:13 AM •
Samsung...
Answered
on Oct 28, 2016
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
