20 Most Recent
GE 28111EE2 Cordless Phone Questions & Answers
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
I cannot get my phone's
Press the "do not disturb" button near the lower-right-hand corner of the base unit.
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/28111_DOM_EN_CL_IB.pdf
I have a GE
that is probably your mouthpiece, it is located on the lower end of your handset and you have to open unit first to have it replaced. you could check that it has contact and nothing is blocking it before replacement.
Regards
I am trying to use
my friend these are known issues and without wasting your time, just know that if you use MagicJack, these phone will NOT ring, and the answering machine will NOT answer. However the phone will light up showing incoming call displaying the Caller ID information.
magic jack works well with for example Uniden 6.0 set.
Regards
My phone has a "Do
It seems you have activated the "Do not Disturb" function on your phone. To cancel this function, in the stand by mode press the Do not Disturb button on the base.
Hope this solves your problem.
Thanks
Change time
The time on mine automatically set itself when a call came in from a phone allowing you to see caller id.
No incoming ring
For GE 6.0:
There is a button on the base lower right corner (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Hope this helps!
New voice mail
put a piece of electrical tape over the light. I cant turn my blue light off either.
Can not get rid of "do no disturb"
Just a shot in the dark (as I'm not familiar with your particular phone), but have you removed the battery for a minute and re installed? The settings should revert to default, enabling the ringer again.
Good luck.
