20 Most Recent Whirlpool RBD305PDS Electric Double Oven Questions & Answers
I assume yiu had the electronic oven control repaired. Sometimes the touch pad also goes bad. I have had to replace them at the same time. If the oven indicator lights showing the oven being on shows up on the display it could be that the thermal fuse behind the oven has gone out. this in in the common line and will shut down both ovens at the same time but you will get the control panel to respond to the touch pad.
Whirlpool... | Answered on Nov 28, 2013
Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
Whirlpool... | Answered on Nov 09, 2013
A lot of people seem to have ran into this problem. I had no luck finding a solution to this problem anywhere on the internet. I finally fixed this problem by replacing the control board. Wanted to put this info out here for others. The part swaps out fairly easy for all of you considering the fix yourself. Sears direct had the cheapest price.
Whirlpool... | Answered on Dec 24, 2012
You need to remove oven top cover--6 screws. You may need to bend 2 flaps out of the way next to power conduit.
Whirlpool... | Answered on Jan 27, 2011
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
https://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Whirlpool... | Answered on Aug 05, 2010
Whirlpool RBD305PDS Electric Double Oven Logo
39 questions posted
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Ovens
  • Whirlpool Ovens
Most Popular Question
whirlpool double oven control panel
  • Ovens
